Question about Plumbing
Salamander rsp 75pump not working, When shower tap is turned on the pump hums but does not pump. Could this be just electrical brushes that need replacing?
    Genius:
  • 1,015 Answers
I would be more inclined to think that pump impeller has something caught in it. There should be a flex coupling of some kind that you can lossen to remove pump from basin. Unplug electrical cord and pull pump out. There should be a removeable slotted cover on the bottom that you can take off to clean impeller. Remove all debris from bottom, wash out with water. Depending on what type of switch you have on your pump you can make sure all water is out of pump and plug in momentarily,rise float to turn it on and see if it runs. If it has apressure switch you won't be able to do this. If you can make it try to run make sure you only try for a few seconds. These pumps are not designed to be run dry. If it runs put bottom cover back on and reinstall pump. If it doesn"t you probably will need a new pump. Thank. Hope this helps.
Posted on Nov 14, 2010
How to increase water pressure on wall mounted shower
Yes,,,
You could fit a shower boost pump if you water supply to the shower is gravity fed. Pump both the hot and cold so that the water pressure is equal...
Salamander pumps are the best and have flow switches which activate when the shower is turned on..
There are cheaper pumps available... you get what you pay for...
http://www.screwfix.com/p/salamander-pumps-rsp50-positive-head-shower-pump-1-5bar/99043
Just for a guide....
Apr 12, 2017 | Home
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
How to find brushes on pump
Brushes are on motors (electrical), pumps are mechanical.
Apr 12, 2014 | Home
1991 s-10 pu//////electric fuel pump not working,is it a blown fuse
i'll try to help. have you checked the fuses and the relays under the hood in the black fuse box? with the key in the on position, can you hear the fuel pump humming? you may have to turn the key on and off several times 15 seconds at a time. if all fuses are good and the fuel pump relays good, try with key on, tap on bottom of gas tank to see if the pump will start to hum. if pump does start to hum, you'll need to replace that pump soon. you may get a couple of starts out of it, but usually not very many. hope this helps and thank you for choosing fixya.com
Nov 12, 2010 | Chevrolet S 10 Cars & Trucks
The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
Had grundfos shower pump fitted, wheneva a tap is turned on else where in house the pump attempts to start !
Hello. Your shower pump is sensitive to the other taps because your installer failed to install check valves in the system to prevent the backflow of water whenever another tap was turned on. J.
May 24, 2010 | Home
Danze D500540BNT Brushed Nickel single handle leaks
only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
Feb 23, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
Easiboost power shower - problem
it comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Feb 17, 2009 | Bosch PowerStar AE125 AE125 Whole House...
New shower installed doesnot always kick pump in
some times if there not enough water flow passing through the pump it wont kick in make shure all other taps ar off an try that ,have you got a good water pressure in you house?
Jan 26, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Plumbing Logo
218 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
