Question about Wurlitzer WR18 CD Shelf System
When I insert a CD to play the shelf pops back open. tkhypes@hotmail.com
  • 2 more comments
  • Theresia Hypes Nov 15, 2010
    Yes...I insert the CD onto the shelf and from the remote push close -- it closes then opens immediately
  • Theresia Hypes Nov 16, 2010
    Yes it stays closed....it doesn't engage the CD
    I'll give that a try this week. although I don't know what shorting the switch means :-(
  • Theresia Hypes Nov 18, 2010
    Will try your solution asap....what does shorting the switch mean exactly? You're working with a novice :-)
  • 11,800 Answers
This happens in only 2 cases:
1 - the end switch of the tray (the switch that cuts the power to the motor when the tray is fully closed) is faulty. To check i you need to dismantle the cd unit and short the switch then reassemble it, put a disk in then manually push the tray in closed position and start the unit. If it works just fine and ejects normally then the switch is defective and must be replaced. If it ejects immediately hen
2 - the controller chip is faulty. The only way to fix that is to replace the entire mainboard and that would cost you as much as a new player.
In that case the player is dead, time for new one.
Posted on Nov 16, 2010
  • Azrael SRL Nov 16, 2010
    shorting - connecting the 2 contact points with a piece of wire.
  • Azrael SRL Nov 18, 2010
    Take the system apart and on the board of the optical unit you will see 2 small contacts - nothing more than 2 small brass blades with a plastic part on one of them; when fully closed the tray hits the plastic part and breaks the contact signalling that it's closed. These small blades are soldered on the board, just join the solder points with a flat screwdriver (also called shorting the contacts) - this should keep the motor running long enough to make the controller ready to start playing and move the laser head. If this doesn't happen and instead the tray is ejected then the controller is faulty.
  • 2,299 Answers
Something is obstructing the tray from closing all the way. Instead of the electric motor burning up the door is opening. Does it do this when the tray is empty?
Posted on Nov 15, 2010
  • Rodney Clark
    Rodney Clark Nov 15, 2010
    It closes and stays closed with no cd in the tray?
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
I have an Sony RX66 the cd changer will not pop to play on.
My sony stereo rx66 after finish to play the first cd stand of going to play the second one, it put the cds one of the top of the other or under the tray. Can somebody help me?
May 04, 2009 | Sony MHC-RX66 Shelf System
Cd case will not open
If you're really brave, unplug the unit and remove the case screws. Pop off the case and get your CD back. The you might need a draw belt. See prbline.com or studiosoundelectronics.com
Nov 15, 2008 | Sharp XL-HP737 CD Shelf System
Not reading any cd format
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software
1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
OR
2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
any probs just mail back and ill help as much as i can
Oct 21, 2008 | Philips WACS700 Shelf System
Singing machine SMG 301 problem
has a bad drive motor, not sure where you can get parts for these
Oct 19, 2008 | The Singing Machine DVD/CDG Karaoke System...
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Jan 25, 2008 | Teac CD-X8 CD Shelf System
Wurlitzer WR18 CD Shelf System Logo
57 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
