Question about Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty
Craftsman 18.5 HP, 42" (Model 917.270752) (about
  • 68 Answers
SOURCE: Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Posted on Apr 26, 2009
  • 68 Answers
SOURCE: diagram for mower belt on model 917250540
SearsPartsDirect.com has parts diagrams that should be helpfull.
  • 86 Answers
SOURCE: Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
Posted on May 11, 2009
  • 376 Answers
SOURCE: belt drive replacement
First you have to remove the top cover over the belt. If it's still on, work it off the pully. Then you have to remove the blade, blade adapter and cover underneath. Put the new belt on the pulley underneath and push it out the slot to the pulley on top and put everthing back together. Hope that helps.
Posted on May 16, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Can i replace a 17.5 hp mower engine with a 18 hp engine?
You will need to shop carefully. That is not too much of a power jump to worry about ruining axles, gears and the like. BUT, do be mindful that you have to shop an engine to match two very important criteria:
Bolt patterns and spacing: This is how the engine will attach to the mower's deck/chasis.
Output shaft length, diameter, taper and if it's keyed or non-keyed.
If looking to just replace a tired old iron horse, similar make and model to the original with slight power upgrade cannot be helped - but the bolts and shafts will be pretty much spot on.
May 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to replace a belt on a craftsman with a 42" deck.What size belt should I get.What length.
Craftsman is made by Murray Corp. who also makes Murry, YardMan, Lowes, Penncraft, and on and on. Go to your local Wal-Mart, Lawn and Garden Dept. and look for the belt that fits the Murray, YardMan, Lowes, Toro, 42" Deck 14-18 HP. Or take your old belt with you, and stretch them both end to end holding the end loops with each hand. Or you could go to Sears and just tell the parts department what your mower is and they can get you a Craftsman belt. It will be the same one you get at Lowe's, Wal-Mart, ect, probably just cost a little more. Sears doesn't make mowers, they just have their colors and names put on by the manufactorer. And Murray of Ohio is the maker of these.
Sep 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Apr 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty Logo
217 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
