Question about IBM ThinkPad 760 EL Notebook
IBM 9547 notebook laptop hardrive problem
I can run the "tests" from it but it will not recognize the hard drive or the cd player. An external floppy drive works, but fdisk does not see the hard drive. I've removed it and checked the connections. Any ideas ??? S/N 78-AYVV9 97/07 Type 9547-U9C .. The cd drive has been replaced with a known good as is the hard drive. Is there a bios setup I can get to or ?? Unable to find any information on this model under lenovo (ibm). thanks for the help
    Genius:
  • 2,028 Answers
You can get a bios flash from IBM that will download to a floppy. Try that and get back to me.
Posted on Jun 18, 2008
What type of ide cable for ibm 9547 hard drive
Connect the hard drive to an USB hard drive adapter then plug the USB adapter with the hard drive into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files and backup or copy them to the computer.
Nov 25, 2012 | IBM 9547-U9J Thinkpad 765L Laptop Computer
Can swappable drives CD and Floppy be used in external cases?
Not sure, but if you can download and copy Ubuntu on CD. It might run off disc with no install.
Aug 29, 2012 | Gateway Solo 5300 Notebook
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
I have a IBM Thinkpad and it says can't find operating system. There are some f1 and f11 options when it first starts but not sure what to do?
When the computer/laptop can't find the operating system it could be caused by :-
The BIOS has been changed and could not detect the hard drive.
or
A non bootable floppy disk is in the floppy disk drive.
or
The operating system files has been wiped or corrupted on the hard drive.
or
The hard drive is faulty.
Check the BIOS configuration to see if the hard drive is detected. If it can't detect the hard drive then the hard drive is faulty.
If there is a floppy disk in the floppt drive, then remove it.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port and if this computer can detect it as an external hard drive and can open the folders and files, then the hard drive is OK. If not the hard drive is definitely faulty.
To get the laptop operational again, it needs a new hard drive and Windws installed on it together with the device drivers and your programs.
If you had not backed up data then the data on the old hard drive is lost.
Aug 20, 2009 | IBM ThinkPad T30 2366 Notebook
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
IBM laptop cant load XP from externall CD drive
If you have a floppy drive on it you are in luck.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310994#XSLTH3135121122120121120120
That would be the most straightforward way to do it.
If not.
Are you able to boot off the external CD?
If so there is another way using the PE , preinstallatoin enviroment.
If not , you said you formatted it externally , which I assume means you have either a 2.5 to 3.5 IDE adapter or a USB to IDE adapter and another PC to format it with.
If you can hook the drive to another PC , you can do the install there , change some hardware settings , run the SYSPREP utility and swap the drive back into the laptop.
Mar 04, 2009 | IBM ThinkPad T23 2647 Notebook
Unit will not boot from cd/dvd, drive test good.
The main programing on the motherboard (bios) should recognize and read from the CD drive, If it doesn't then there is three possibilities as to the problem. 1- the bios have glitched, so, start by doing a bios flash. 2- the optical eye or the reader board in the CD drive has gone out, and the drive will need replaced, 3- there is a malfunction with the motherboard, and the board will need to be replaced. These three are the only possibilities and fixes for this problem.
Jul 26, 2008 | IBM ThinkPad 600E 2645 Notebook
I don´t have internal cd, only external(usb)
You will need an internal CD drive for the machine in order to load XP. If it doesn't recognize the external in the boot menu, then there is no setting to get it to.
Jul 23, 2008 | IBM ThinkPad 600E 2645 Notebook
Cd drive for ibm laptop t30
you can purchase a usb to ide adapter and use a standard internal pc dvd drive or buy a usb dvd burner.
Nov 09, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad 760 EL Notebook Logo
479 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
