Question about Acer Aspire 5500 5570-2609 Laptop
My acer laptop 3600 gets hot - Acer Aspire 5500 5570-2609 Laptop
    Brigadier General:
  • 8,909 Answers
Laptop Processors do rum hot. There have been reports of people burning their legs because the exhaust is around 70 degrees Celcius when working hard.
Ensure that the air flow is not restricted and the hot air can exhaust easily from the grille/vent.
If the fan runs at high speed all of the time, it probably needs cleaning out.
Use a vacuum cleaner and with its pipe, place it over the air inlet grille/vent while the laptop is switched off. That will clear most debris from the fan blades.
Hope this helps.
Posted on Nov 14, 2010
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Aspire 3600 pci modem
I assume you are referring to the PCIMCIA driver ?
CardReader Vista Download (3680)
CardReader XP Download (3680)
CardReader XP Download (3600)
Jun 01, 2010 | Acer Aspire 3680 Laptop
*laptop* mouse and keyboard not working.
if you dont no what your doing leave it alone daaaa;
May 01, 2010 | Acer Aspire 3600, 5030, 5500 Keyboard...
I would like driver multimedia controler aspire 3600
http://www.acer.com/worldwide/support/download.htm
Jun 17, 2009 | Acer Computers & Internet
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
I have some melted keys on my acer aspire 3500 notebook i would like to replace those keysn how would i do this? i tried to call acer customer service but i could not get through
Replacing keys on laptops is really a pain, and would require scraping a keyboard to get the keys....Anyways you can buy a keyboard for your laptop relatively cheap from Ebay. Between 10-24 dollars. I took the liberty to do the ebay search and have provided you a linke to many keyboards just for your laptop.
http://computers.search.ebay.com/acer-aspire-3500-keyboard_For-Laptops-Notebooks_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ158885QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Apr 24, 2009 | Acer NSK8458AN Keyboard
Mouse keeps freezing
It maybe getting too hot. You need to blow out all vents and fans. I have seen acer laptops get too hot, easily, so you need to make sure it is dust free.
G'luck
Nov 11, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3600 only background picture, nothing loads.
you operating system is corrupted...causes :- improper software installation...O/S too old..and many other causes...you can try
go on pressing key "F5" as soon asyou switch on then a menu will appear select safe mode...
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Sep 06, 2008 | Acer Aspire 3680 Laptop
Loss of graphics - Acer Aspire 3600
Hey there besafe, the problem of your video driver is easily solved. If your computer is new, then you may have the driver CD for the motherboard installation. Alternately you can download the driver from the motherboard manufacturers website, assuming the video is onboard. If it is an installed video card, and you are without the driver disk, you can usually get the specific driver from the manufacturers of the video card website, specific to your OS. These drivers are easy to install therefore the best first step. If that does not work, then look at the hardware. If you have a video card installed, reboot your computer and enable the onboard video. If this works, then your video card may need replacing, preferrably with something having a higher built in memory and more suited to your usage. Hope it helps. Good Luck!
Jan 28, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5500 5570-2609 Laptop Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
