Question about Saeco Magic Comfort Plus Espresso Machine
Steamer port is clogged - Saeco Magic Comfort Plus Espresso Machine
  • 1,089 Answers
Hi
Could be but it could also be your steam solenoid. They will get stuck to where they can't open because ther is a calcium build up in the system. I would suspect that your water hardness is set too low. The best setting is 4. If you don't hear a cleck when you push the steam button its your solenoid.
Posted on Nov 14, 2010
Yvulcan steamer wont get steam whatthe problem
Is the burner coming on? Check all the steam line and nozzels, they tend to get clogged up with calcium from the hard water.
Aug 30, 2014 | Vulcan Hart Convection Steamer, Gas,...
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Aug 27, 2014 | Royal RY7910 Procision Deluxe Upright...
Unclog steamer so it will suck water?
To unclog any sort of water clog mix white vinegar 1/3 cup, with 2/3 cups of water, Than pour mixture into suction opening and let lie for about 5 minutes.
May 15, 2014 | Dirt Devil CE7000 Easy Steamer Upright...
SOLUTION IS LEAKING FROM MY BISSELL 1697 CARPET STEAMER WHEN IT IS STORED
you should always empty the steamer before you store it away it stops it clogging up.
Sep 13, 2012 | Bissell 1697-7 Powersteamer Pro Deluxe...
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
We have two steamer . The water comes out the delimer port cap . The gasget is broke in half and we are getting a new one but would that make about 5 gallons of water come out and goes all over the...
1 Your fill valve may be stuck open.
2 The water level control board or probes may be defective.
3 The unit is full of lime scale and interfering with the water level controls.
Oct 18, 2010 | Vulcan Hart VSX5G Counter Convection...
Steamer appears clogged. How do I take the steaming arm off to clean?
depends on the model try reaming out with a small thim paper clip, straighten out and slide up the little hole on the tip of the wand contact me www.lavazzarepair.com
Nov 12, 2009 | Lavazza Espresso Point Capsule Machine
New solenoid drain valve for cleveland steamer
The correct cleveland part # for your valve is 22221. If you have the correct valve there should be no extra ports. The steamer will flush itself when you turn it on, and periodically if there is the optional blow down timer installed. Hope this helps
Apr 02, 2009 | Cleveland Electric Powered Convection...
Saeco Magic Comfort Plus Espresso Machine Logo
76 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
