Washing machine is 18 months old. It just quit with an E5 error and a tub full of water that will not drain. We made sure the drain hose was not kinked. We again tried a basic rinse and spin cycle and cannot get the water from the rub. We manually emptied most of the water now. GE 9150
  • Joy Bowes Nov 15, 2010
    Do you have any recommendations for me to check for something stuck in the pump impeller?
  • Joy Bowes Nov 19, 2010
    Thanks anyway. A repairman is coming out today. Waited too long for a solution.
  • 15,935 Answers
This is a slow drain error.
There may be something stuck in the pump impeller - the pump may be bad - or the coupling.
Something is causing the water not to pump out of the machine - and it's one of those.
Posted on Nov 15, 2010
  • blueextc3221
    blueextc3221 Nov 19, 2010
    The pump has likely failed. What is the full model # please?
    Thanks!
  • blueextc3221
    You must remove the hoses from the pump and physically inspect.
My fisher paykel dishwasher will not drain water it washes a while and when spray water it stops and e5 comes on screen leaving water in machine
See if the water hose to the unit is kinked or otherwise restricted. If the water hose seem ok them you might have a defective water inlet electro valve. The video may help, be patient e5 is explained Fisher and Paykel Dishwasher Error Codes
Dec 14, 2016 | Fisher Washing Machines
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
Error code E 18
make sure there is nothing stuck in the imp[eller, which is the pump at the front bottom of machine. ( make sure it turns freely ) also try draining the machine by way of drain hose in a bucket. if it drains this way ok then fault is waste pipe plumbing blockage. hope this helps
Jan 02, 2012 | Bosch Washing Machines
Error e1. washing machine will not drain. The tub is full and between the wash and rinse.
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Aug 10, 2009 | Haier HLP21E Top Load Washer
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't empty water
i assume you mean dishwasher and not washer ck drain hose under sink if not installer properly hose tends to pull down and kink ..should be installed vertically not horizontal also be sure to clean under inside screen in bottom may be plugged also have you replaced disposer or installed one recently if so be sure plug in drin connection has been knocked out..if that is a washer get as much water out as possible lean washer backward against wall pump may be plugged pump just twist locks in bottom of tub and hose clamps can be removed with fingers NO TOOLS NEEDED!!!!!!!!
Sep 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
