Question about Cell Phones
I need to use a headset with my phone for work. I can only hear if I use the handset. When I use the headset I can't hear. i press the headset on button and nothing happens. All I hear is a click. I know it is not the headset. i have treid 2 different ones and I have tried plugging in 2 different cords into the headset port. i thought the phone was defective but when I plug in the handset into the headset port the headset on/off button works. What is going on?
  • Cell Phones Master
  • 4,737 Answers
Please let me know with more info, it's not possible to help you without knowing the Phone Model and Make. Thanks.
Posted on Nov 14, 2010
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
People can not hear the caller on Cisco 7945G
Could be a bad hook switch on the phone if you plug a different phone in does it work as it should?
May 07, 2014 | Cisco 7945G IP Phone
Handset on panasonic cordless only works with headset
It appears there is something internally wrong with your handset. We recommend you use the below link to setup service.
www.panasonic.com/repair
Apr 28, 2014 | Panasonic KX-TG5422M Cordless Phone
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
I have tried all configurations settings with my new Plantronics S11 headset, and with some I can hear on the headset, but the caller can't hear me. With others the caller can hear me, but I can't...
You need to remember a couple of things when using amplifiers and headsets. Normally they will not work if you connect them to a phone with cordless accessories. Also, you need to make sure that you're connecting the amplifier to the HANDSET jack on the phone (this requires removing the handset off of the phone to access an open line). Give that a try and you should be fine. If not, contact your retailer or Plantronics at 800-544-4660 x5538 for warranty service.
Jul 02, 2011 | Plantronics S11 Consumer Headset
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Jun 10, 2011 | Plantronics S12 Headset
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Jun 03, 2011 | Plantronics S11 Headset
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
NBX 3102 Headset jack stops working
You should be using a plantronics a-10 interface cable if you are using hardwire headsets. get rid of the m-20 amplifiers. I support 280 of these phones and the best solution is to replace the phone. Power cycling the phone will help for a while but the problem will come back.
Feb 02, 2009 | 3Com NBX 3102 IP Phone
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
