Question about Viking VMOS200 Microwave Oven
I have no heating all other factors operate - Viking VMOS200 Microwave Oven
  • Viking Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 15, 2010
Why does my ge profile spacemaker not heat up
There maybe so many factors. How old is your microwave. From your description, I believe you may have to change your Magnetron. Maybe the magnet is cracked.
Jul 28, 2014 | GE Profile Spacemaker Over-the-Range...
Machine goes through the motions but water comes out cold
Hi,you have not stated how old this unit is ? I think they are supposed to last for 4-5 years but I've known some to break after just one year and others that worked great for 15 years or more.
Read more: What is the average life span (during normal use) of a microwave oven? ' Answerbag http://www.answerbag.com/q_view/1540053#ixzz1TQlW7RlH
Carbon Heating Lamp for microwave oven strong heat resistance. More than 6000hrs lifespan.
From a website...
7.3.7 Magnetron Life Expectancy
The typical life of a magnetron tube is approximately 2000 hours of operation. Some factors that can diminish the life of a magnetron are: 1) no-load operation, 2) operating with too much metal in the cooking cavity, 3) line voltage consistently too low or too high, 4) improper phasing, 5) improper installation or removal, 6) replacing associated high-voltage components with substitutes that are incompatible with the system design, 6) continual operation at the upper limit of its heat tolerance due to inadequate air circulation, 7) obstruction in the wave-guide, 8) failed stirrer operation.
We use ours about 15 mins a day which would mean 2000 hours would be reached in 22 years but as they say there are a lot of factors which may reduce its life. The design and parameters of the oven will make a considerable difference. E.G. A highish power magnetron always underrun will last much longer than a smaller one run at its max ratings.
A restaurant might reach 2000 hours in only a year or so and industrial machines whether for cooking food or other processes will require frequent magnetron replacement.
http://www.alibaba.com/product-gs/439406670/Carbon_Heating_Lamp_for_microwave_oven.html
Jul 28, 2011 | AEG Microwave Ovens
The microwave oven does not heat up when operated.. :(
The problem is most likely caused by a bad magnetron, there are two additional parts that can be a factor, the high voltage capacitor and diode. Chances are the repair will exceed the cost of a new microwave oven.
Mar 21, 2011 | Daewoo Microwave Ovens
Microwave does not heat up food
The common problem is the magnetron that heats the food, there are two other parts than can be a factor, the high voltage capacitor and diode. In most cases it is cheaper to replace the microwave oven.
Mar 14, 2011 | Kenmore Microwave Ovens
Heard a pop and now the jvm2070 will not heat anything
This sounds like the magnetron has failed, also! the high voltage capacitor and diode can be a factor, since all the above work together in generating heat for the food. If the magnetron has failed it is cheaper to replace the microwave oven.
Mar 10, 2011 | GE JVM2070 Microwave Oven
My sharp R-1492 microwave was running and popped and now it wont heat.
It sounds like the magnetron has failed, but there two other parts of concern, the high voltage capacitor and diode can be a factor, they work together to heat the food. Parts and labor can be high, depending on the nature of repair.
Mar 06, 2011 | Sharp R-1492 Microwave Oven
Oven heated just minutes before and now it wont heat anything
There are three causes that would do this, the magnetron "common problem" or the high voltage capacitor and diode can be a factor, the above items work together to heat the food. The repairs can approach the price of a new one.
Mar 02, 2011 | Whirlpool GMH5184XVS 1000 Watts Microwave...
Kenmore Microwave not heating. Turns on, lights, clock, etc.
The problem is one of three things, the magnetron has failed "common problem" or the high voltage capacitor or diode can be a factor, all three work together to heat the food. Depending on repairs the cost can be as much as a new microwave oven.
Feb 27, 2011 | Microwave Ovens
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
My GE White Spacemaker Microwave just stopped heating-you hear the motor running but the light inside grows bright to dim by a few watts while going thru any cycle of heating. Any answers?
The magnetron has probably failed, there are also two other parts that can be a factor, the high voltage capacitor and diode, the high voltage is generated by these items which in turn heat the food.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Viking VMOS200 Microwave Oven Logo
115 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
