Question about Uniden BC244CLT Base Scanner
How to remove a noisey scanner programmed number
    President:
  • 2,761 Answers
For a temporary fix just press the LOCKOUT key while the scanner is stopped on the noisy channel. For a more permanent fix you can program 000.0000 into the channel, effectively deleting the programmed frequency from the scanner's memory.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC244CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Posted on Nov 15, 2010
How do you clear error code c0650 for bizhub 211
Scanner home sensor error. Is it locked up?
you may want to look under the display pannel on the left side I believe. is a scanner lock. I actually turned one on before. just noisey but caught it quick enough. I would check that out
Nov 09, 2017 | Konica Minolta Office Equipment & Supplies
How do I remove the X from Scanning?
The scanner can only record what it sees.
What you have is a software issue.
If you can not prevent the X from being on the wrist bands in the first place, I would contact Meditech support. to see if the software can be programed to omit it.
Jun 30, 2014 | Honeywell 4600g Wired Wand Barcode Scanner
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
How do i program a pro-135 200 channel hand held scanner from radio shack
  1. 1. Press "MAN."
  4. 4. Press "MAN."
  • Hope this helps.
Nov 26, 2011 | Radio Shack Radio Communications
How do I reprogram the Radio Shack PRO- 2026 Police Scanner
To program a known frequency into the scanner:
- Power the scanner ON.
- Press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program.
- Press PROG.
- Enter the frequency, including decimal point.
- Press ENTER.
The frequency is now programmed into memory. To continue programming, start over with a channel number, or just press PROG to advance to the next channel.
For more details on programming your scanner, follow this link:
http://support.radioshack.com/support_electronics/doc16/16902.htm
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 09, 2010 | Radio Communications
Can't program numbers in it the scanner
Press PGM, then enter the channel you want to store a frequency, then press PGM again, use the number keys including the decimal point you want to store, then press ENT to store the frequency into the channel....you can get your frequencies for your state at www.RadioReference.com ....hope this was helpful
May 03, 2010 | Radio Shack Pro-2018 Scanner
How do i remove already stored frequencies
From the manual:
deleting frequencies from channels
1. Press MAN.
2. Use the number keys to enter the channel
with the frequency you want to delete.
3. Press MAN again.
4. Press PROG to enter the program mode. MAN
changes to PGM.
5. Press FUNC.
6. Press CLEAR. The frequency number changes
and 0.0000 appears.
Feb 10, 2010 | Radio Shack Pro-2054 Base Scanner
Programming a pro 137 scanner
1. Press SCAN/MAN to enter manual mode.
2. Press EPGM to put the scanner in
programming mode. PGM appears.
3. Use the number keys to enter the channel
4. Press SCAN.
5. Use the number keys and •CLR to enter the
frequency, including the decimal point you
want to store.
6. Press EPGM to store the frequency.
7. Press EPGM again. The Edit Channel menu
appears.
8. Rotate the knob to select 1: Edit Car#, then
press EPGM.
9. Use the number keys to enter the car number
in 3-digits, then press EPGM.
10. Rotate the knob to select 2: Edit Tag, then press
EPGM.
11. Use the number keys to enter the tag then
press EPGM.
12. To program the next channel in sequence,
press Menu then repeat the steps from 3.
For more details, you can download and print the complete operating manual by following this link:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000137_PM_EN.pdf
To be certain that you have all the active frequencies in your area, visit:
Dec 28, 2009 | Radio Shack Pro-97 Handheld Scanner
Need the numbers to program in scanner
The "numbers" to program, like in frequencies? Radio Shack used to have local booklets of frequencies for scanning, you might check with them.
Oct 13, 2009 | Office Equipment & Supplies
Uniden BC244CLT Base Scanner Logo
49 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
