Question about KitchenAid KERA205PSS Electric Kitchen Range
Kitchen aid model # KERA205PSS is not baking correctly. The top of the cakes get done and the bottom doesn't. Is this a problem of the baking element?
  • 3 Answers
SOURCE: Oven top element does not come on when baking
the top element is for broil only. if you have convection mode try that
Posted on Nov 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Large element burns high
The problem is in the switch not the element.
Posted on Mar 24, 2009
  • 206 Answers
SOURCE: bake or broil elements won't work.
Have you checked the main breaker or fuse for the stove? (lucky you did not get shocked.)
Do you have power to the stove elements?
If you have power to the stove elements, then I would look for a burned out wire in the path from the controls to the element. First place to start would be at the actual connection to the elements.
And glad to see you are still with us to ask this question. (((SMILE)))
Posted on Aug 18, 2009
  • 574 Answers
SOURCE: Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
Posted on Apr 05, 2010
heatman101
  • 43501 Answers
SOURCE: Not baking correctly...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
Why does the bottom of my cakes burn before the center is done?
Because your oven gets too hot on the bottom part. Use a rack to position your cake in the centre of the oven or - if the bottom of the cake still burns - insert a baking tray between the bottom of the oven and the rack on which you bake the cake on.
Sep 19, 2014 | Baking
Kitchenaid kera205pss convection oven feature not working
Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
Apr 20, 2014 | KitchenAid KERA205PSS Electric Kitchen...
heatman101
Apr 27, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Apr 05, 2010 | KitchenAid KERA205PSS Electric Kitchen...
Things bake unevenly. Cakes get brown on edges
first make sure you are not blocking a rack.air needs to circulate from the bottom to the top.never cover a rack with tin foil or a large pan. if alls good you may have a temperature problem.check temp if its off raise oven temp as high as it goes hold bake button untill it beeps it will display 0 go up to raise temp up down to lower you can only adjust 35 deg.Good luck!
ERIC
Jan 21, 2010 | Kitchen Ranges
Oven with convection - when baking cookies, cakes, etc they aren't getting done. Bottom and middle is soggy. Both coils look to be heating, convection fan is working.
Set the temperature one position higher. Convection ovens have a more even heat spread so if you used to bake at the top of your old oven it will now be slightly lower temperature
Dec 06, 2009 | GE Profile JB900BK / JB900KK / JB900TK...
How to replace bake oven element on kitchen aid model KERA205pass5
This is a very simple repair. The following link explains how to replace the bake element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If you have not purchased a replacement element yet, the part number is 9755770. The cheapest place I could find the element was appliancepartspros.com for about $54.
NOTE: The element may be slightly mishapened during shipping. If you have to straighten the element to install, use care that you do not crack or break it.
If you have questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Sep 16, 2009 | KitchenAid KERA205PSS Electric Kitchen...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
How do you turn on the kitchen aid superba electric oven, I'm trying to bake a cake...please help
Check the manual, or your 8 yr old.
seriously though if you have an auto set use it and the oven should go to 350. otherwise push bake and set temp then push start if you have that button. hope the cake comes out good.
Jun 14, 2008 | KitchenAid Kitchen Ranges
GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Oct 07, 2007 | GE JSP26 Electric Kitchen Range
KitchenAid KERA205PSS Electric Kitchen Range Logo
69 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
