Question about Toshiba SD-K730
"Disc playback unauthorized Consult owners
2 Suggested Answers
  • 99 Answers
SOURCE: Toshiba D-vr3 no longer reading dvd discs
try cleaning the lazer. You can pick up a cd cleaner at any dollar store.
Posted on May 20, 2010
"Hi Have a Problem With my Pioneer BDP LX91 Blu ray player,
Hi we had the same problem have you tried going into home menu/ initial setup/go down to playback/find BDMV/BDAV playback priority and make sure BDMV is highlighted and all should be OK.
Hope this helps if not could be a drive failure but try this first.
Oct 17, 2012 | Televison & Video
Game has error, says to consult Wii operations manual
It's most likely the disc that is causing trouble. If all of your other games work, it the game you bought. I had the same problem with MySims Party, I went to the store where I bought it, they gave me a new disc, which worked fine.
May 25, 2012 | Nintendo PokePark 2: Wonders Beyond
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My model is one pictured on your "Ask a Question".
quick-start guide:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/
Audio/QuickGuide/Archive/aud_qguide_cddd4500.pdf
operation manual:
Audio/Manuals/Archive/aud_man_cddd4500.pdf
Apr 28, 2011 | Sharp CD-DD4500 System
I have a friend who has a PIONEER Bluray Player BDP LX52.Despite having updated it to the latest firmware(3.71)it is not playing the RED(Morgan Freeman,Bruce Willis)Bluray.Sometimes he gets the menu and...
The firmware update needs to be done again.
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
IMPORTANT: Prior to following the steps below, go to the Drivers & Software section of the Pioneer eSupport Web site to check for available firmware updates. If a firmware update is available, it will be posted there with a list of improvements over the original or any previous firmware version. Some disc playback issues may be resolved by ensuring the BD player has the most current firmware installed.
  1. Ensure the Easy Setup procedure has been completed on the BD player. NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
  2. Ensure the inserted disc is compatible with the BD player. NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
  3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step. NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
  4. Use a soft cloth to clean the disc.
  5. Examine the disc for any cracks or scratches that might be interfering with playback.
  6. Wipe the top of the disc tray using a soft dry cloth before placing the disc on the tray. Attempt to play the disc again.
  7. Attempt to play another disc. Remove the disc from the BD player.
  8. Turn off the BD player.
  9. Unplug the power cord of the BD player from the electrical outlet.
  10. Let the player remain without power for 1 minute.
  11. Plug the power cord back into the electrical outlet.
  12. Turn on the BD player.
  13. Insert the disc into the BD player.
  14. Attempt to play the disc.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
Apr 08, 2011 | Pioneer BDPLX52 BluRay Player
When i try to write a video on a DVD, it says "write failed". What do i do??
Double check that the disc used is compatible, consult the User Manual.
Has the disc been Finalized?
Al
Feb 07, 2011 | Computers & Internet
Need manual for Funai SV2000 Model#WV20V6
Visit www.funai-corp.com and under manual type your model to download pdf.
Jan 06, 2009 | Funai TruTech DVDVCR Dual Recorder
No owner's manual for LSGN 1938 video camera
Had the same problem. The solution is to choose "finalize" from the playback menu.
Dec 14, 2008 | Panasonic Video Cameras
Toshiba SD-K730 Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
