Question about Bosch Ovens
I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
  • 78 Answers
Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
*** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
Posted on Nov 14, 2010
Oven does not heat to selected temperature.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 13, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
Bottom oven does not heat up fan works
The element is usually located at the rear of the oven compartment,behind a removeable cover, this is also where the fan is located.
Hope this helps.
Nov 29, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
My hot water heater is burning fine, but still no heat in my house, got a new thermostat still no heat
you should talk with an electrcian or home helper becuase either some wires or conections arnt working or your heating system is blocked
Jan 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Dec 08, 2007 | Ovens
Ovens Logo
398 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
