Question about Neff 3.21 cu. ft. / 91 liter Upright Freezer G1524
Freeze temp on electra freezer letters n&s whitch turns freezer colder freezer is on orange light on and defrosting
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
The temp on my freezer is on normal and was working ok then just stopped and the red light is on turned up the temp to make it colder and the fast freeze but not working and everything is defrosting
Hi Denise, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will typically sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Sep 24, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Aug 28, 2011 | Frigidaire Freezers
Old Kenmore frostless upright freezer 19.6 cu ft. Model 38202. It is running but not freezing. Is it worth a service call?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 31, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Need to replace defrost heater in freezer
It could be the defrost time clock. if this is a self contained freezer the timer is kind of oval in shape their is a small hole with flash light should see some thing moving if not it's the timer you can turn adjusting stem until you hear it click that should put in defrost if you have an amp meter you can measure the amp draw should be around 2-3 amps or their is a klixon high temp limit is bad you likely need service. Tom
Jun 17, 2009 | Freezers
OF light won't turn off to allow freezing
i belive that the temp select you can choose temp, but when the min temp is selected, the next choice is OF, try resesting the control to a warmer/ or colder temp.
Nov 16, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Neff 3.21 cu. ft. / 91 liter Upright Freezer G1524 Logo
23 people viewed this question
Top Neff Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Freezer Expert? Answer questions, earn points and help others
