Question about Dell E173FP 17" LCD Monitor
My monitor loads up, but the screen goes black, i can turn the power button on and off it will show the picture for a few seconds then black again, it load up everything the picture just goes black any ideas what the problem is?
  • Dell Master
  • 4,737 Answers
This must be caused by a bad or damaged capacitor(s) on the Inverter board (power supply board). The only solution is to replace the defective capacitors. To do this, you'll need some electronic tools like soldering iron, soldering wire/paste, etc.. and most of all the capacitors with the exact Unit. You'll need to refer to the one on the board for the unit, it should be written on the capacitor itself as "?" followed by the value. Actually this is related to backlight, but since backlight shows up and you could see the picture for a short period, then the reason is behind the regulators, means the capacitors. If you have idea how to solder or how to remove the soldered components, go ahead and replace them. You'll be easily able to identify them, bulged or exploded or broken.... If you don't know how to use and how to disassemble the monitor, I don't recommend as you might damage other components which will cause another bigger issue. I hope you understand.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 14, 2010
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Screen cutting out
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Hannspree HH251H 25" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
Alun Cox
