Question about Brother MFC-8460N Laser Printer
Resetting "Replace PF Kit 1" message
My LCD displays "Replace PF Kit 1". I've read in relation to other Brothers that this can be reset.
What is the procedure for this MFC-8460N model?
Thanks!
  • 4 more comments
  • deez606 Jun 18, 2008
    Oh yeah, BTW: if it's not clear, I don't want/need to replace the Tray 1 PF kit. It still works. It seems to be very common with this Brother that things "need" to be replaced before they actually do.
    I wonder why that is? [duh: $$$].
  • Anonymous Sep 01, 2008
    I got this same message on my MFC-8460n m/c this morning. I've just gone through the maintenance 88 routine and this appears to have cleared the error. I actually had to follow this process twice more as after resetting the PF Kit, I got a further 2 error messages to replace the Fuser & Laser. By going through the maintenance 88 routine for both of these, my printer is now printing & copying again.
    Thank You!
  • magicman420 Oct 16, 2008
    I had the same problem for an 8460, and the same solution for teh 8860 worked.
  • Nicole Sep 17, 2013
    I spoke with tecnical support and they told me that this error ment that I had a virus. From doing my research it sounds like it is paper feed issue. Does anyone know?
  • Anonymous Mar 19, 2014
    how to replace the pf kit
  • produkey
    produkey Jun 29, 2018
    Thanks, you guys that is a great explanation. keep up the good work in your granite blog. windows 10 ***********
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Posted on Feb 08, 2010
  • 2 more comments
  • All4Help Nov 17, 2010
    Thank you... I have a MFC 8860dn model... This was very helpful, the so called tech support wanted to charge me almost $80 to fix this... and BTW the never would tell me just what that error message ment. thank you again for the posting....
  • sagie Sep 11, 2013
    tHANKS PROBLEM SOLVED
  • Joseph P. Lewcun Aug 02, 2014
    cool- glad this worked!
  • Heike O'Day
    Heike O'Day Nov 02, 2017
    Sweet! 7 years after you answered this question, it still is a valid answer! My brother DCP8060 prints again! Thanks a bunch!
I had the same issue with a MFC-8460, and the same solution as the 8860 worked.
Posted on Oct 16, 2008
Thanks for the help
Posted on Jan 06, 2010
    New Friend:
It came up with another error for laser so I did the same thing again and scrolled through to laser and it fixed the error.Thankyou
Posted on Nov 15, 2014
From what I could figure out from experimenting on an MFC-8860DN we are junking the procedure is:
1) Turn off printer
Not sure if this applies to the 8460. Maintenance menu feels dangerous, so use at your own risk.
Posted on Aug 07, 2008
  • Dianne Sep 26, 2011
    it worked!!! Thanks
SOURCE:
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
Message reads "Replace PF Kit" but everything is working fine. Is this an error and if so, how do I clear it??
The PF kit has life expectancy, if everything works fine just reset its counter.
Press "3 & 9" together, select the desired parts counter reset.
Aug 19, 2014 | Brother MFC-9320CW Color Laser Printer -...
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Have a Brother mfc 8460n reads replace PF kit 1 need to now what that is and how to replace it
Replace PF
Kit1
It is time to replace the paper
feeding kit for Tray 1.
Call Brother Customer Service to replace the
PF Kit 1.
You can read more by clicking here or copy and paste link to your browser address bar:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002000/cv_mfc-8460n_usaeng_user_d.pdf
then go to page 110 (you can type 110 at the top of the page to quickly get to the page)
I hope this helps. Sorry for the small font
Mar 10, 2011 | Brother Office Equipment & Supplies
Have replaced drums in printer and after turning the printer off and on several times, there is still a message saying "drums end soon"
1) Press the 1 and 7 buttons at the same time in the ready
status.
(2) The "Reset Menu" will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the "1. Reset 2. Exit"
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Note:
- All periodical replacement parts are always indicated on the LCD even though their lives do not reach 0 %.
- The PF kit2 is always indicated even though Tray 2 is not installed, or it is not supported for the model to be used.
- The machine returns to the ready state automatically if no panel operation is implemented for 60 seconds.
Jan 17, 2011 | Brother MFC-9420CN All-In-One Laser...
Mfc-9420cn pf-kit2 reset, how to reset the counter after installing new kit
Press Menu/Set, 7, 4. Press down arrow to select PF Kit 2 and press Menu/Set. The confirmation message appears on display PF Kit 2. Press 1 to reset or 2 to cancel. PRESS 1.
Nov 03, 2009 | Office Equipment & Supplies
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-8460N Laser Printer Logo
48,331 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
