Question about Culligan Under Sink Water Filter
I replaced my Whirlpool Ultraease Undersink Filtration filter model WHEEDF and th Filter 1 of the pair of filters leaks. I have applied teflon tape to the threaded pin of the mounting unit and the leaks have not stopped. Has anyone found a fix?
    Genius:
  • 1,015 Answers
I would shut water off and relieve pressure. Remove filter houseing and inspect rubber gasket on bath sides, clean it off and clean inside of cap where gasket sets and on top of housing. Make sure there are no rough spot on either surface. If there are you can smooth them out by using fine grit sandpaper,no coarser then 120 grit. Wipe all surfaces clean and apply 5-6 wraps of teflon tape on threads on filter housing. Before you put gasket back in place you can put a light coating of petroleum jelly,vaseiline or similar,on both sides of gasket. wipe off excess. Reinstall filter and housing. tighten securely. Turn water back on and check for leaks. If it still leaks you can tighten a little more. If it still leaks I would replace gasket. Hope this helps.Thanks
Posted on Nov 14, 2010
I had this problem, too. It started as a fairly slow drip. When I removed Filter 1 for inspection, then reseated it (after not seeing anything wrong), the leak become much worse, spraying out the seams where the filter & housing meet. It turned out not to be a problem with Filter 1 itself, but rather a crack it the housing that ran from the lip of the inner cylinder ring, all the way to the ring's base. How/why this occurred I don't know, but it means I will have to buy a new installation kit to replace the housing. >:[ Note: You can save yourself from having to reinstall the hosing by pushing in on the housing's connection rings, while pulling the hoses out.
Posted on Nov 12, 2011
Unit leaks after changing filter
I have one of these units, just replaced it last night. First off, determine where it's leaking. The filter cartridge is generally inside a cylindrical cup with a screw thread at the top. Leaks here would either be that the wall has a hole in it (replace the canister), the male threaded area has been damaged and is not round (replace the canister, the mating female thread is damaged or out of round (replace that part), or you're leaking through where the threads meet. (If the leak is not in this are, then the leak-fixing turns into generic plumbing - find out where the water if getting out. If it's hose, replace the segment, if it's a valve, replace the valve or valve seat.
Assuming it's the filter holder - check both thread faces for contaminants or grit. Some filters (like mine, fed with well water, come out covered in gack. If that gack- fine sand/silt from the water, gets in the threads, it can create a widening there on the thread that the screwing-in just spreads down the thread. In any case, clean both surfaces carefully with a clean, lint-free cloth.
After that, I've had great success wrapping a couple of circles of plumbers teflon tape onto the male thread of the filter holder. Get a roll of reasonably wide teflon plumbers tape and run it clockwise (looking down from above the cup) around the thread 2 or three times, keeping some tension on the tape, and then tension tearing the tape. Smooth it down, clockwise. Now mount the filter to the screw in point, and then carefully screw in the filter body. You wrap the tape this direction so that tightening the screw will tend to flow the outer end of the tape toward it's end, rather than back on itself. hand tighten, and then, when firm, tighten another quarter turn or so. The tape will do a great job of sealing the slightly larger gaps between the threads, and probably fixing the leak.
BTW, good pricing on the filters here: http://bit.ly/1Opkuh8 though back ordered at present, and here
http://bit.ly/1Rwg9q0
Good Luck!
Nov 24, 2013 | Franke Replacement Cartridge For Frxs2...
Gxrlqr filter leaks
MAKE SURE THAT WHEN YOU REPLACE THE FILTER IT IS IN THE SAME ORDER AS THE ONE YOU REMOVED OR THAT IT IS THE SAME MODEL TYPE REPLACEMENT , I WOULD TRY TO TURN IT AROUND FIRST , A THIN WRAP OF "WHITE PLUMBERS TAPE" , AROUND THE SCREW TOP INNER SEAL MAY CORRECT THE LEAK , ABOUT THE FILTER , WELL , IT MAY JUST BE SIMPLY IN THE REVERSE ORDER , TRY TO FILP THAT OVER , AND WHEN YOU RESEAL THE CAP ON THE FILTER MAKE SURE THAT THE SEAL IS ON PROPERLY , APPLY PLUMBERS TAPE ONCE AROUND , AND *"BEFORE YOU TIGHTEN IT" , GENTLY , REVERSE THE CAP BACKWARDS , SLOWLY , UNTIL YOU FEEL IT "SEAT " PROPERLY , "THEN" YOU MAY TRY TO RE-TIGHTEN IT . THIS SHOULD REMEDY YOUR LEAK , IF IT CONTINUES MAKE SURE THEN THAT YOU HAVE THE CORRECT REPLACEMENT FILTER MODEL FOR YOUR PARTICULAR ITEM . HOPE THIS HELPS YOU . NOW GO FIX IT ! GOOD LUCK .
Aug 19, 2012 | General Electric GE SmartWater Household...
Filter for UltraEase water filtration system?
This may not be the problem now but by the sound of the malfunctioning water lines etc., it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 08, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
GE Water Filter - GXSL55F - Need Replacement fitting-
remove the old one then take it with you try going to Lowe's or Home Depo or any plumbing supply they will point you in the right dirrection
Jan 30, 2009 | General Electric GE SmartWater Household...
Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Water filter housing leak
Leak just stopped on its own. No idea why.
Oct 10, 2008 | Whirlpool GD2SHGX Refrigerator
Culligan Under Sink Water Filter Logo
1,226 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
