Question about Panasonic NN-T990SA Microwave Oven
After setting the time cook on my NN-T990SA, it shuts off within 3 seconds of hitting start. This happens almost every time and the microwave will not cook. Can this problem be fixed or should I consider scrapping it and get a new one?
  • blacky47 Nov 14, 2010
    Thanks, that is the way I was leaning.
    Jim
  • Panasonic Master
  • 11,800 Answers
The oven shuts down almost immediately after the inverter board - the one that powers the magnetron - gets activated. This is a big fault, repairing it can be done strictly only by a specialized repair shop and because of that it will be expensive.
So yes, i think it's time to cut your losses and get a new one.
Posted on Nov 14, 2010
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
My timer stops after 5 seconds.
Since no model number was posted, I have to give a general answer.
Since it was posted under Panasonic, I'll assume it's a Panasonic.
See if one of these describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
If it stops after 7 seconds, it has a problem with the inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Sep 26, 2011 | Panasonic NN-T990SA Microwave Oven
Panasonic microwave, returns to clock setting after 3 seconds
this sounds like one of two things to me it maybe if the unit has inverter on the front of it the magnetron or the inverter itself both repairs can be expensive if its both and that does happen around 80.00for the magnetron and poss not much change out of 120.00-150.00 for the inverter sorry its best with that fault to take it to a shop or call an engineer unless you are confident with this sort of unit its best left to a pro
Oct 02, 2009 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
422 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
