Question about Acer AL1916W 19" LCD Monitor
I have an acer p241w it wont turn on at all, it was on and we had a power outage and now the power is back on it won't turn on, i think it might've popped a fuse or something on the board but i can't figure out how to open the monitor up to look at it, there are no screws and i don't wanna mess this thing up trying to pry the back of it off, any help would be appreceated
  • 5 more comments
  • Darrell Deatherage Nov 14, 2010
    I have eliminated everything, it is certainly from the monitor the graphics card works fine i plugged in another monitor and used the same power cord and it works fine, so i kno it is the monitor im farel certain itis a fuse, or i hae also red thepowerttons dont work sometimes. no lights come on at all when i plug it in, and hanks to that poweroutage im farely certain it is just a fuse, i am a farely handy guy when it comes to electronics, im just not sure how to get this monitor apart, seams it has to be pryed apart but i don't wanna break it.
    I know it is not my graphics card i know it is in the monitor i have hooked up another monitor with the same power cord and it works just fine, so i know it is my monitor, all i need to know is the steps on how to take the back off the monitor so i can check the fuses on the power board
    i've taken it apart, did'nt find any fuses all capacitors and relays look fine, when i plug it in i can hear electricity shorting something it's kinda of like crackling noise coming from the power board, not sure what's wrong sill tho
  • Darrell Deatherage Nov 17, 2010
    is there a place i can buy a switch board for it? I can install it myself, i looked at it and did'nt see any bad solder joints or capacitors or anything, but i'll look again, any website that sells these boards would be appreciated!
  • Darrell Deatherage Nov 20, 2010
    everything looks good on all boards, i don't have a multi meter so i can't check voltage on the switch board, but wondering, since when i plugged the power cord in i heard crackling , any idea's what might be burnt or bad? is it the switch board or the power board? not sure, any help would be appreciated!!!!
    i don't have a al1916w i have a P241W are they the same thing? just diffrent size?
  • Darrell Deatherage Nov 21, 2010
    Don't they mak a replacemet pwer supply bard?
    President:
  • 2,923 Answers
Check the link below and you will be redirected to the PDF service guide of Acer AL1916W:
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Starting on page 25, you will see on how you can open the back cover.
Thank you and good luck!
Posted on Nov 20, 2010
  • Melvin Ramos
    Melvin Ramos Nov 21, 2010
    I think you have a power supply unit that went bad and needs to be checked out. You need to have a service adjustment done by your Service Tech. You just can't fix the power supply unit without clearing the buffers, and all the other procedures needed to fix this monitor.
    Thank you!
  • 570 Answers
1 . OK so your monitor will not turn on but your computer seems to be running just fine, this is something we have all come across at least once. So first thing you check is to make sure that the power cable behind the monitor is inserted all the way, as in its not loose. If you have checked and it is connected and your sure that power is running to it, then we move on to the next step.
2 . If your monitor shows a light whether green or any other color then power is going to your monitor, so then we grab a laptop or another desktop if there is one available, and try to connect the monitor to the desktop if it does the same thing on the other desktop or laptop, then we can assume it is your monitor.
3 . If however on the other desktop you do see an image, then it means your video card from the original desktop computer is not working and you need to replace it.
4 . If you don't have a laptop or another desktop computer available, then you can check by turning on your computer and if you see that the monitor sounds like its turning on and a green light turns on then turns orange, its more than likely your video card, if it just stays orange and never turns green, or makes a sound of it turning on, then its your monitor.
Hope this has been helpful in some way.
Thanks for using Fixya.
Posted on Nov 14, 2010
  • Sonavati Rathod Nov 16, 2010
    If there is crackling sound then please get your switch board checked there might be a problem in the switch board.
    There might be lose connections as well , so please get it checked.
    Thanks.
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
Acer aspire x1430 won't turn on
CHECK LAPTOP POWER SECTION
Mar 08, 2013 | Computers & Internet
Need a Acer p241w service manual
Suggestion take a look on the body of the old power supply and write down the voltage and amperage millie-amps or what ever and if you have some old power supplies from an old phone or what ever, match the values of it to your old power supply you might get lucky.
Mar 07, 2013 | Computers & Internet
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Comes on for second with picture and goes black. turn off and back on will do same thing.
Sounds like it is probably the inverter board. You can find one on eBay, they are usually the problem, not the backlight or screen. Simple change usually and you are good to go. Very inexpensive too, search ebay for inverter board acer P241W, or I have gone to laptopaid.com too.
Dec 17, 2009 | Acer P241W 24 inch Monitor
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Acer P241W LCD Monitor
mine freezes in standby and I have to turn it off and then turn it on again each time
Jan 24, 2008 | Acer AL2016W 20" LCD Monitor
Horizontal lines lcd monitor
I think monitor is defective. Contact manufature
Dec 13, 2007 | Relisys RLT1720 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
