Question about Motorola Mobility RAZR V3
Charging A Motorola Razr
How Do You Know When A Motorola Razr V3 is Fully Charged?
  • 4 Answers
If you look at your phone screen while the batteries are charging, it should say Charging, and when it is finished, it will say Charge Complete.
Posted on Jun 21, 2008
Can i know the usual battery life of moto v3 after of charging...on my,,,its almost 2 hr about continious of use...
Alot of phone calls, texting and game playing will significantly drain the battery. But with out much use a fully charged battery could last up to two days.
Nov 13, 2009 | Motorola Mobility RAZR V3
Motorola razr v3
Does the LCD light up when you plug it in for charging? If no then you probably have a charging port(on the phone) problem. Should run you about 10-15$ to get it repaired. Good Luck!
Sai.
Jul 14, 2008 | Motorola Mobility RAZR V3
It usually doesn't show that it's charging anymore, like a blank screen.
Jun 20, 2008 | Nokia N95 Cellular Phone
New phone razr v3i charging issue
Have to phone sent in for warranty and request a "loaner phone"... sounds like the power drain is too high on the device and it needs service or replacement... another sign would be the unit heating up hotter than normal - is that happeneing?
Feb 08, 2008 | Motorola Mobility RAZR V3
Motorola RAZR Troubles
try charging the battery, and if that does not work have the firmware relash on your phone by a professional mobile technician.
Jan 03, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3 wont turn on.
go to a professional mobile repair tech and have the phone fully service and if the does not work have them reflash the original firmware or upgrade the existing firmware on the phone.
Hopefully that corrects your problem :)
Dec 25, 2007 | Motorola Mobility RAZR V3
Razr V3 wont operate out of the box
Sounds like your battery has dropped a cell
try replacing the battery
Dec 02, 2007 | Motorola Mobility RAZR V3
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Doesnt Turn On
try a new battery fully charged,problem with your charging block probably,had the same problem with my fone and it was the charging block problem.take of the back case, you'll see two screws there ,unscrew them lift the back gently a bit and then screw it back on,will fix the charging problem temporarily or atleast you'll find out where the problem is.gud luck
Aug 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
