Question about Singer Inspiration 4210 Mechanical Sewing Machine
I have bought a singer quick fix and I can not figure out how to load the bobbin to sew the instructions that came with the singer are in spanish
  • 340 Answers
Hi
You can download a free manual from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 4210 and click on search.
On the next page click on free download!
This manual is in French, English and Spanish.
Hope this helps.
Posted on Nov 15, 2010
  • theresasever Apr 03, 2011
    I am having the same problem and your link does lead to the correct model number for this type of machine.
  • hazelgrace
    hazelgrace Apr 04, 2011
    I thought the person was looking for a manual for the Singer 4210 not the Quik Fix that they mention in their post.
    You follow the exact same procedure using the link above but instead type FIX in the search box and this will lead you to the manual for the Singer Quik Fix.
    Hope this helps!
Singer 4622 installing bobbin case
The owner's manual should have instructions.
Also search for some videos on YouTube:
Bobbin case seating 2
Inserting Bobbin Top Drop In
Fixing Top Load Bobbin
Jan 22, 2016 | Singer Sewing Machines
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
Bobbin threading for Singer 2001
singer has some free manuals
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 117) & click search
or try youtube
May 15, 2012 | Singer 6423 Sewing Machine
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Bought used--trying it out---top stitching is
Check to make sure that the thread running between the tension disks. A quick check is to lower the presser foot and then pull on the top thread. If you do not feel any tension, then it may not be ran in between the disks. Also, check to see if your bobbin is inserted correctly going counter-clockwise. This can cause the "loose" loops and thread jams in the bobbin casing.
Feb 10, 2010 | Singer 5050 Mechanical Sewing Machine
Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Dec 29, 2009 | Singer Sewing Machines
I need to load the bobbin for my singer 247, I have no manual
I am a veteran seamstress and I may be able to help you. it sounds as though you just have the wrong needle in the machine or the needle is in backwards.. Machine needles are different lengths according to what machine it is. The needle could also be dull on the point. Try this and see if it helps. Also your local sew shop can help you no charge if you just go in and talk with them. The techs enjoy helping for the most part I have discovered.
Jan 08, 2009 | Singer Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
4,658 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
