Hi i recommend you to try Recoverfix for windows data recovery software. By using this tool you can easily recover your crashed files. The software free demo is available you can download it from here: http://www.recoveryfix.com/recover-windows-data.html
What sounds like sparking could be a head crash. If it is a head crash then you are basically finished with the drive. They all go sometime. The only safe way is to have another backup drive and keep a current second copy of all information which you must save. Even this procedure is not completely safe. The hard drive should not make any noticeable sound (not more than a fan sound). If it does, then it is probably dead or about to die. If the information on the drive is IMPORTANT, then you can contact a data disc recovery site which can help you with removing most of the data from a crashed disc. I pioneered this recovery system idea many years ago and several companies exist now to recover data from crashed discs.
DataKit - The Best Free Data Recovery Software
Handle the problems of lost data easily: Accidentally Delete, Formatted Drive, Hard Disk Damage, System Crashed, Virus Attack, System Interrupts, Unexpected Power off and other improper operation.
Recover all Lost/ Deleted/ Formatted/ Corrupted Files, including Documents, Pictures, Video, Audio, Email and other files from Computer and other storage devices with NTFS, FAT16, FAT32, exFAT, EXT file system.
If you have not upgraded of changed your power supply, you probably should. Also, you could be having troubles with your RAM. Have you try to perharps repair or re-intall window?
replace the floppy drive it sounds as if the drive motor is bad the hum is a inactive drive motor when a floppy is good it will usualy click as it comes on along with a green indicator llight
What is model and what version of windows
