Question about Acer Aspire One Netbook
How do i remove the HD in my Acer netbook to replace it?
  • 270 Answers
Removing the hard drive from an Acer Aspire notebook just takes a few minutes. here is how:
> ? Turn the Acer Aspireoff. Unplug all cables attached to the system and turn it face-down. Remove thebattery. ? Remove the screws holding down the hard driveaccess cover and pull the cover away. The location of this cover varies frommodel to model, but it is readily visible on the back of the computer. SomeAcer Aspires' hard drive bay covers have only one screw; others have two. ? Grab the hard drive andpull it out at an angle. On most systems you need to push the drive to the lefta little bit and then pull up. Handle the hard drive from its sides. ? Replace the hard drivecover and screws. Put the battery back in and return all cables to theiroriginal location.
Posted on Nov 14, 2010
How to remove and replace ram on acer aspire one d255e and remove and replace the keyboard
Download the service manual from here: http://www.manualslib.com/manual/249205/Acer-Aspire-One-D255.html
Feb 24, 2015 | Acer Aspire One D255E13438 Netbook
Cannot open my acer netbook
CANNOT OPEN IT TO SEE THE SCREEN AND KEYBOARD? (FLIP IT UPSIDE DOWN AND NEAR THE TOP AND TO THE RIGHT AND LEFT SIDES YOU WILL SEE SLIDE BUTTONS. ONE IS FOR THE BATTERY LOCK AND ONE IS TO LOCK THE NETBOOK SHUT. JUST SLIDE THE BUTTON AND YOU WILL BE ABLE TO OPEN IT.) OR DO YOU HAVE HAVE A BLACK SCREEN WHEN YOU PUSH THE ON BUTTON.(FLIP THE NETBOOK OVER AND YOU WILL SEE 2 REMOVABLE COVERS. REMOVE THE SMALLER COVER THAT HAS ONE SCREW. GENTLE REMOVE THE PIECE INSIDE, COUNT TO 5, THEN PUT IT BACK IN AND REPLACE THE COVER. THIS IS THE NETBOOK MEMORY STICK AND IT WILL RESET THE DISPLAY SO THAT THE SCREEN WILL NOW WORK AND YOU WILL BE ABLE USE YOUR NETBOOK AGAIN.
Jan 21, 2013 | Acer Aspire One Netbook 8.9" Notebook
How do i remove the HD in my Acer 3935 notebook to replace it?
Pop the battery, remove the lower case cover & memory, remove the screw holding the HDD caddy in and lift it out via the rubber tab. please rate me if this helped you, thx.
It starts on page 33 of the manual.
Service Manual:
http://www.manualowl.com/m/Acer%20Computers/Aspire-3935/Manual/114291
Jan 15, 2012 | Acer Aspire One Netbook
I cracked my screen. how much to replace it?
Contact Acer and provide them with serial number of your laptop to see if they have the part for you then i would take it to a local repair place and have them charge you just for the install of your new part ordered from Acer
Mar 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer netbook wont turn on .... power lite green some fan noise black screen no hd activity
Your netbook computer is not POSTing, which means that it has not passed the Power On Self Test.
Claim warranty support, as a computer technician needs to diagnose the faulty components within the netbook computer.
Sorry for this terrible news.
Thanking you kindly
damnor01
Feb 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one d250 netbook with windows xp sp3 and realtek hd audio- sound AND video stammers!!!   i have Bitdefender security suite and all drivers acer asked to install?  is it a problem of...
I give you the solve. 1st format the OS drive. Then install the OS again, after that install Bitdefender Security. After installation of bitdefender restart the laptop and run for drivers installation. Remember first bitdifender then driver. Becouse Bitdiffender block all driver's for security.Hope you understand. Pease ask me if you want more help.Thanks.
Feb 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
How easy is it to replace a netbook screen - it's an Acer Aspire 1
The following tutorial will guide you to replace the screen of your Acer notebook.
remove-lcd-screen-inverter-board-acer-aspire
Hope you find this information helpful.
Thank you for choosing Fixya.
Jan 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook Logo
407 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
