Question about Citizen Blue Angels Skyhawk Watch
It has been in my drawer for several month how do I get it started gain
I have an aquaracer automatic and it gains up to 6 - 10 minutes in a day. I have had it fixed before and it was fine for 12 months and now it has started again. Is this normal?
All of the watches I have owned have run for many years without attention and when you buy one as expensive as yours, I would expect similar reliability.
I suggest that you speak to the maker (or contact them via their web site "Tag Heuer.com") and discuss your problem with them.
May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
TAG watch is running fast
You need to find a qualified watchmaker to correct this problem.
If the movement was replaced twice the same problem would not be happening again and again unless there is something you are doing that puts the watch in some kind of field to magnetize it or the place you took it to did not really do anything.
My guess is they did not do anything since you say they oiled the crystals. Just oiling a watch will not solve this problem. A qualified watchmaker would know this.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 11, 2010 | Watches
My Timex men's watch ran fine for a couple of months and then started loosing several hours over a 48 hour period. I changed the battery but after a while it began to do the same thing. The id on it is:...
If it is only two months old and you have proof of purchase (did you register the warranty?), the take it back.
Most watches have at least one years warranty.
Mar 08, 2010 | Watches
I replaced the battery and still doen't work It's just been sitting in a drawer for about 6 months
If you take your watch to a repairer for your make, he should be able to put it right for you.
Feb 05, 2010 | Watches
Omega Seamaster gaining about 10 minutes per hour
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
Jun 07, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Screen not working T Touch Titanium (Totally Useless)
I suggest you have to find the decent watchmaker and do not use dealers services anymore.In my opinion you have been overcharged in both cases.
Consider replacing touch screen if it is damaged and then sell it on ebay (anyway you do not like it). For watch in working order you have to get quite a decent money. If you gonna sell it as it is, you will get pennies only.
Later just buy another make and forget about this unlucky example. :))
Dec 07, 2008 | Tissot T-Touch T33159851 Wrist Watch
Setting sub-dials when several months wrong
Try the manufacturers web site, you can normally find all the information you could require
Dec 11, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Blue Angels Skyhawk Watch Logo
23 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
