Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet control locked - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 1,902 Answers
Hello
You can unlock the control by resetting it, to reset try pressing the END OF CYCLE button and hold it for 15 seconds. This will resolve the problem...please get back to me if you have any other questions.
Kevin
Posted on Nov 14, 2010
  • micheleswain Jul 14, 2011
    Kevin, your direction worked like a charm. Thank you so much, Michele Swain
SOURCE: whirlpool Duet
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Posted on Feb 03, 2008
SOURCE: Whirlpool Duet Washer
EXCELLENT & SIMPLE SOLUTION -- THANKS! Philip from Toronto
Posted on Sep 03, 2007
SOURCE: WHirlpool duet washer is stuck on "controls locked"
PUSH END OF CYCLE SIGNAL(LAST BUTTON ON THE RIGHT)FOR THREE SECONDS AND IT SHOULD WORK.
Posted on May 06, 2008
SOURCE: whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Posted on Oct 20, 2008
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Posted on Aug 22, 2010
Whirlpool duet dryer says control locked what do i do?
Hi
Press and Hold the End of Cycle Signal Button for 15 seconds, this will unlock the control lock of your Whirlpool Duet. Hope this helps...please post back for further assistance.
Daniel
Sep 14, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to release Whirlpool Duet button control lock button
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Mar 20, 2011 | Whirlpool Washing Machines
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet accidentally put into "control lock". How do you reset it?
The following link explains how to correct the control panel lock issue on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,188 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
