Question about IBM ThinkPad T42 Notebook
LCD and main board hinge broken - IBM ThinkPad T42 Notebook
I need to know how the sreen wirering goes in a toshiba c655d-s5300
Usually located around the hinges.Be careful... Try removing the hinge clips there is a ribbon cable ...these can break easily.but check that the connection into the main board has not dislodged before inspecting the screen area.the screen housing clips together at the bevel edges.be aware that faults can just be failed backlight,,,,inventor,,,,loose connections ,,,,broken ribbon,,,,dead or cracked lcd.
Feb 19, 2015 | Toshiba Computers & Internet
My dvc NV-GS25 lcd screen is not working
Common problem with this model, flat cable that connects lcd assembly to the main board is broken, replacement part comes as hinge assembly witch includes cable and the hinge.
Nov 11, 2009 | Panasonic NV-GS25 Mini DV Digital...
My screen is broken
If the LCD panel is broken it must be replaced. The job is done removing the upper part of the laptop, keyboard and panel to disconnect ribbon cable from main board and undo the hinges. Once display is out, remove front display panel and replace LCD display. Part price and procedure depend on the model.
Sep 22, 2009 | Compaq Presario Notebook
I have a Panasonic pv-gs35 Camcorder when I open the lcd monitor the screen turns all white. The viewfinder works ok. Should I have to replace The lcd monitor?
first check the LCD connection, try to reconnect the flexible cables on the LCD board,
second, replace the flexible cable goes throungh hinge.
if those won't work, you may need to replace the LCD or main board.
May 17, 2009 | Video Cameras
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
The LCD only works in a certain position
Flat cable connecting LCD unit to main board broken. Whole "shaft unit" have to be replaced ( LCD hinge with flex cable). Panasonic part #
LSEP8449A1
Nov 14, 2008 | Panasonic SDR-H40 HDD Camcorder
Broken LCD repair
Boss this is not an easy job. To replace the LCD u will have to separate the top portion from the other. I would suggest take it to a reliable technician and he will do the job for u.
There is a flex cable that is connected to the main board through the hinges of the phone and even if u manage to separate the two care should be taken while fixing it again as the new flex (that comes with the LCD display) may get jammed if wrongly done. Only an expert will help u here
Nov 04, 2007 | LG VX8300 Cellular Phone
Cover replacement
HI You can try with the helping pictures I collected from the links below. I hope you can find some similar techinque. 1) http://www.daydeal.com/pages.php?pageid=5 2) http://repair4mobilephone.org/disassembly_motorola.html Actually, the hinge removal of Motorola phone is the most difficult task. You have to be carefull or else you will brake the LCD cable since the connector of the other end of the LCD cable is located near to the hinge. If you applied too strong force there, you wil brake the LCD cable easily so to me, in order to remove the hinge, you should disconnect the both ends of LCD cable connector. One end will attach to the main LCD near to the speaker, the other end will connect to the main board. Disconnect both of the end in order to release the pressure when you apply on the edge of the hinge in order to seperate the LCD part and the main board with keypad part. Good luck. Regards, Joseph
Mar 08, 2007 | Motorola Mobility V170
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
IBM ThinkPad T42 Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
