Question about GE Microwave Ovens
My microwave JVM1442WA does not heat. The clock and lights still work. Any suggestions? Is it worth a repair call or should i replace it? It was installed in 2000. Thank you
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
sharcnet
  • 2130 Answers
SOURCE: GE XL1800 1100 Watts Microwave Spacemaker
Yes, it could be the Magnetron. If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Posted on Jan 24, 2008
rhozel2010
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
MNfisherman
  • 11896 Answers
SOURCE: the microwave will not heat anymore...it still
See this article: http://www.repairfaq.org/sam/micfaq.htm#micnhono
Under the heading "No heat but otherwise normal operation" you might beable to fix the first three items listed if you have access to a continuity tester. You would probably need a pro for other causes under this heading.
See also fuses and thermal switches in other parts of the article. __________________
Posted on Sep 30, 2009
Testimonial: "Thanks for the feedback..."
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE profile microwave JE2160 no longer heats
If it's less than one year old, it would be fully covered under warranty and I'd suggest contacting GE Customer Service here to get it fixed free.
If it's the magnetron and it's outside the 1-year labor warranty, but within the 5-year magnetron warranty, the labor to replace the magnetron would probably run about $50-75, which can instead be used toward a new oven.
If you or someone you know might want to replace the magnetron, and it's within the 5-year magnetron warranty, GE will send you one free. Call them at 888-239-6832 with your model, serial, and manufacturing date.
Some info on troubleshooting:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably just have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Dec 26, 2009
How do I know if it is worth fixing my microwave. The lights work. It will not heat up.
Hi, I'm Al the owner of Big As Auto Repair
When my microwave went out I found out it was going to cost me more to repair it then to replace it, so I went and bought a new one. Go to: repairclinic.com If you need further assistance visit my website below. Have an awesome day! Auto Repair
Feb 22, 2015 | Microwave Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
I have a GE Spacemaker Microwave - over the stove model - clock, light, turntable and timer all work, but does heat the food - any suggestions? The microwave is 4 years old - is it worth fixing? Thank...
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven. This is what produces the RF energy that heats your food.
Here's what you need to determine whether or not its worth fixing:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. You will need to ensure the oven is UNPLUGGED before servicing anything inside the cabinet. You will need to remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3, The magnetron replacement part number for the model you have listed is WB27X10305. The average cost is about $80. NOTE: I found the part listed for the best price at appliancepartspros.com at a cost of $76.
You need to decide whether or not $80 and the amount of labor involved is worth the effort as opposed to replacing the entire oven at a higher cost and less labor (other than the installation). Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts.
Aug 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a model #565.68421 purchased in April 1998. Clock and timer work but it stopped working otherwise. Is it worth exploring repair? Any suggestions for trouble shooting?
At the price of a new microwave, it is not really worth exploring any further. If the magnetron gave out, it's cost alone without labor would be excessive.
Dec 28, 2009 | Kenmore Microwave Ovens
Will not heat
Is this a microwave you are talking about? If the clock and timer works, the light comes on and the tray revolves, but it doesn't cook food or heat stuff up, it is most likely the magnetron. Probably best to just buy another, as the cost of repairs not worth it.
Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
