Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printing comes out wavy. Lines are not straight.
4 Suggested Answers
SOURCE: printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Posted on May 16, 2010
  • 1456 Answers
SOURCE: Our phaser 6360DN is leaving
Hello
Perform a head cleaning by opening up your printer in "Devices and Printers." Click on the start menu, and then click on the "Devices and Printers" option located in the bottom right corner of the start menu panel. Right-click on the printer that is giving you trouble to bring up the printer properties.
Click "Troubleshoot" on the pop-up menu to start up Windows automatic troubleshooting. The troubleshooting program wizard will run and ask you a couple of questions about your problem. Complete the troubleshooter, and then print another page and check it to see if any lines appear.
Check your task bar for any printing software that will show you the ink levels. Check the indicators on the printer as well to make sure the ink isn't running low. If the ink is running low, replace the ink cartridges based on the user manual provided with the printer.
Clean the print head of the cartridge by removing the ink cartridge and taking a corner of the cloth and dabbing it in alcohol. Run the cloth over the ink deposit point found in the lower bottom region of the print cartridge. Allow the cartridge to air dry before reinserting it into the printer.
Check the printer for any paper jams, and run a nozzle check and cleaning from the printer. The printer has menu buttons and features with which you can manually perform much of the maintenance that is required to keep it running at top-notch levels.
GOODLUCK
Posted on Nov 26, 2010
  • 385 Answers
SOURCE: my pixma ip5000 printer had
Hey!Go to printers and faxes on xp or printers in control panel and on the ip5000 picture,right click and go to the properties of the machine!It will open a window with tabs at the top!Click on maintenance and select print head alignment there!The machine will either do it manually or print a couple of pages where you need to select the correct value for each line!There is step by step instruction on what do to when you start doing it!Good Luck!!
Posted on Dec 08, 2010
My pixma ip5000 printer had a paper jam and subsequently the print head seems to have gone out of alignment.It is printing in wavy lines instead of straight!! As I have 150 booklets to print by Friday I...
Dec 08, 2010 | Canon Office Equipment & Supplies
When I print an excel page showing gridlines the lines are not straight but wavy and some of the numbers on the sheet are not visible
Cartridges are not alighned.
Remove one of the cartridges and insert it back.
The printer will print an alighment page. There are instructions on the page to place it on the scanner and to press the Scan button.
For alighment to be successful the printer has not to missing any ink.
Instead of removing and inserting a cartridge, you can use Maintenance tab in Printer preferencies to strat printhead alighment.
Aug 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
Feb 17, 2010 | Dell 3110cn Laser Printer
Printing wavy letters instead of straight
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
Aug 12, 2009 | Wacom Intuos2 Grip Pen (XP-501E) Digital...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,846 people viewed this question
old marine
old marine
