Question about Stoves 720EF Electric Double Oven
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove 720ef
  • Anonymous Mar 30, 2014
    don't know which of the buttons to hold down or press
  • 250 Answers
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Posted on Nov 18, 2010
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jun 17, 2010 | Stoves 720EF Electric Double Oven
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
Mar 20, 2010 | Whirlpool GBS277PDS Electric Single Oven
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
562 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
