I have 3 cat5 cables going from my router to 3 rooms. The router has a LG N1T1 network storage device attached. all 3 rooms get internet ok. Room 3 can see the storage device on list of shared devices but no access. When i move room 3 computer to room 2 then fine. Suggest the cat 5 cable is faulty?
    Scholar:
  • 124 Answers
As you are able to go to internet from room 3 through the same cat5 cable then i dont think its a cable issue. Please check Storage device if there is any access permission/deny needs to be configured.
If that doesnt help , you can try once by interchanging the cables between the one going to room2 and other one going to room3.
Best Regards
Posted on Nov 15, 2010
Reset n1t1
Download the LG NAS Initialization software and burn the image to a CD or DVD. Put the disk into the LG and turn it off. Hold down the backup button and while continuing to hold the backup button you turn it on. Continue to hold both buttons for about ten seconds. Let go.
Nov 05, 2013 | LG 1 TB 1Bay N1T1 Network Storage with DVD...
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Got a home network with a cable modem, router in my living room, and a laptop and desktop in bedrooms. Router is connected along with the cable modem in the living room pc. Mcafee firewall said that i had...
the problem is is your pc has a built in modem???model of laptop and model of desktop???
contact me here if you want some help..stormblade002@yahoo.com
Feb 06, 2010 | Computers & Internet
I have a broadband DSL modem/router in my home office. I also have 2 CAT5e ports there. I want to feed the Internet signal from the router (one of the ports on the back) through a CAT5e point up to my...
Hi Joe,
How are you connecting to the port in the back of your router? if you have crimped a male plug on to some UTP cable then this may be the problem. UTP cable has a solid condutor and needs a different male crimp plug than UTP patch cable, which has stranded conductors.
I suggest you connect the UTP cable between the office and the loft to an RJ45 wall or surface socket in the office, use a terminating tool designed for the make and type of outlet you use, i.e. if using an ADC socket use the ADC termination tool. The sockets are designed for solid cable and have a colour code for you to follow. Then use a factory terminated patch cord between this socket and the router port.
I assume you have terminated the cable from the office onto one of the patch panel ports and want to use a patch cord to patch from this incoming socket to the sockets that are terminated onto the cables going to your other rooms. If you have access to a laptop connect this directly into the router port and ensure you have an internet connection, then plug the patch cord connecting the loft port into the router and take the laptop into the loft and ensure you have a connection at the incoming port on the patch panel. If you get the connnection there then use a factory patch cord to patch to a room you would like a connection in and then take the laptop to that outlet and ensure you have a connection.
If you want to run outlets in multiple rooms without re-patching every time then you will need to have an active switch in your loft and connect the port from the office to this and then patch out of the switch ports to the various room outlets.
Hope this helps.
Cheers, Jason
Apr 27, 2009 | 10 10 Computer Patch panel
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Multiple router
Yes, you can use multiple router on one single internet line, in order for you to do that you need to connect the second router to the main one using a CAT5 cable/Ethernet and everything should be ok already.............
Oct 24, 2008 | Linksys WRT54G3G Wireless Router...
How to run cat5 for phone wire
You could, but common practice is to make all the runs "home runs". Pick a closet or basement or some centrally located place and run all the cables to that spot. Then you can use a $10 block from Blowes Home Dumpo Maynards and create a distribution point.
Carl
Aug 21, 2008 | Computers & Internet
Cat5e 350mhz wire
What you can do with the cat5 cables is plug the wire into the PS3 and the other end into your home router or switch. This might be a problem if your router or switch is in another room or so but it will most likely give you less lag.
Hope this helps, let me know if ya have problems connecting if you decide to use the cat5 wire but it should be about the same setup as using wireless.
Aug 14, 2008 | Cat5e 10ft White 350MHz Stranded Snagless...
XE103 stealing bandwidth
Just a wild guess based on your description is that your hub steps down the network to match the slowest network device on the chain, and it's seeing a device on the far end of one of your XE103's running at 10Mb or maybe even 1Mb depending on the location of the XE103 and the structural resistance of your building. Hubs generally match network speed for all ports where a router is generally port independent.
Sep 11, 2007 | NetGear XE103 Transceiver
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
