Question about Toshiba 40H80 40" Rear Projection Television
40h80 stk 392-110 ic
Where are the ic in this set and are they soldered in and is the a easy fix I don't want t pay 400.00 to have it fixed the bule is out of and can bring it back but will move up and down thanks Tom
  • william cosentino May 11, 2010
    can you check for typos and please don't abbreviate for "ic" and such and i will be glad to help> :)
  • Toshiba Master
  • 8,617 Answers
They are located on the signal board in that chassis they are side by side on two large heat sinks
Posted on Jun 18, 2008
Toshiba 40h80 red light blinking
I would suspect the problem is in the convergence circuit---only one simple way to know---get at and un-solder all 18 pins on both the STK chips it uses.
Once they are free try to turn set on--if it comes on one of the chips is bad and both will have to be replaced.
Dec 05, 2012 | Toshiba 40H80 40" Rear Projection...
Double image
If you can solder, yes this is not a hrd fix my friend. Inside this set, standing up, will be two square black IC's up against a large metal piece called a heat sink. These two convergence amp IC's need to be replaced. They are called STK-392-040. You can get the parts from here: http://www.partstore.com/PartSearch.aspx?PartNumber=STK-392-040&x=12&y=13 Do not forget though to get heatsink compound to install on the backs of the new IC's before you replace them. If you do not have the skill to solder and unsolder, see if a friend can assist you who does, like I said you can buy everything you need for less the 100 bucks. one more bit of advice. You do not want to order any cheap 10.00 replacemnet IC's as they are generic and do not meat the manufacturers specs. Buy only good quility parts or you will be in the same boat in a few months. Good Luck
Jun 28, 2007 | Samsung PCL5415RB 54" Rear Projection...
Want better stk options. pl help!
Use 392-150 the can handle higher current, if not use 392-120. Make sure you use heatsink compound and don't get the "cheap" ics- you get what you pay for.
Dec 13, 2011 | Philips Televison & Video
Color will not match up
if your talking about the sets convergence does not line up and it looks like a 3-D picture than The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 08, 2010 | Hitachi 51UWX20B 51" Rear Projection...
My tv toshiba 40h80 the red and yellow line up but the blue doint it moves up down but i caint get them to line up with the reds and yellow.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | Toshiba 40H80 40" Rear Projection...
Mitsubishi vs5043 convergence
Your chassis is a VZ3 that chassis should use two STK 391-020 ICs Its an easy repair Mitsubishi usually will not blow resistors when the ICs go out. You can get the replacement ICs at the following link and they provide free step by step instructions with pictures so if you have even basic soldering skills this isa job you can do in about 30 minutes . Heres the link.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi VS-5043 50" Rear Projection...
RED CONVERGENCE STILL OFF
Next step should be to check the fuse-resistors and low values resistors for open conditions as well the solder joints on them.
These parts are located near the STK ICs.
Also if you can measure the voltage that power up the STK's. If you do not have the schematic diagram, check the ICs data sheet to know where the voltage is getting to the ICs.
You may have to do the convergence adjustment manually after you replaced those parts.
Good Luck.
Mar 10, 2008 | Televison & Video
Philips 55PW6393
A set beeping doesnt have to mean your CRTs are dead. Its more than likely something in your power supply. Do you have any diagnosis or soldering skills?
Jan 19, 2008 | Philips 55PW9363 55" Rear Projection...
Color Problems
need to replace 2 stk392-110 convergence ics
Apr 07, 2007 | Toshiba 40H80 40" Rear Projection...
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
