Question about Sony Playstation 3 (PS3) Console
Ok SOOO I have a PS3 and it keeps saying maximum amount of power blah blah blah ok so the situation was that a few months ago i let a friend borrow my ps3 for 2 days in exchange of his xbox 360 which was a big mistake. Anyways after we exchange back this stupid *** UGGHH lost my original ps3 controller usb ports so I had to go to a local gamestop called "Babages" ? i think and i bought an energizer usb port that said it could charge PS3 controllers so I bought it. Well It was working like when I bought it but not when I was playing, it would only work when I'm watchingg some vids, and I turn off the controller,?? so I got pissed, HAHA. Well anyways my PS3 Plug broke and we had to fix it after 2 months, I got my PS3 back(YEY) but its really a bummer after not playing for 2 months, that my controller is low on battery, so I tried charging it, nothing, again, nothing, I tried my old method of watching some ;p you know and turned off the controller, and still nothing, what shall I do??
I was about to remove game from my ps3. The power went off for a few seconds at the same moment I tried to remove it. Now my ps3 will not come on or remove the game. any suggestions.
Unplug everything and let it sit for a few minutes. Then plug it back in.
If it still doesn't work, it is probably just a bad power supply. See if you can borrow a friends power supply and test your ps3 with it. If it turns on then go buy a new power supply.
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
My playstation 3 was repaired by Sony about 7 months ago. It's been working fine. My son hooked it up to his TV today to play the new NCAA Football 11. When I hooked it back to my TV I get absolutely...
First connect the PS3 to the TV you want it on. Then try resetting the display resolutions on the PS3 by holding the power button for a few seconds when the PS3 is off until you hear 3 beeps. That should re-detect the video and should solve your problem. Hope this helps!
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
Internet turns off
It's a problem with your unit making a connection to your router. You can do one of a few things:
Uninstall and reinstall your router. Keep all settings default (if you don't, write down everything you do) and keep it to only one encryption key at max.
Distance from PS3 to router can make a huge difference, especially if it's an older router. If you can try either moving the router or the PS3 closer to eachother.
If it is an old router, you may want to consider getting a new one. Some experts will tell you that Wireless G routers are the best for gaming, which is somewhat true but you need to be willing to spend a good amount of money for it. I bought a Belink Wireless N router and my connection is so fast they make me the host of just about every online game. It ran me $60. My router is maximum 15 feet from my PS3 and it goes through 2 walls.
Your type of internet connection could effect it as well. If you have cable it's going to be fast but inconsistant; causing dead moments in your connection. If you have DSL it will run a little slower but very consistant and will almost never cut out.
Words of wisdom: Never turn off your PS3 from the back when the system is powered on; Once a month use canned air to clean out the ventalation system in your PS3; Keep good distance around your vents to give it a healthy air flow; Never set it on carpet as this could pull up more dust and dirt than usual; and when inserting your PS3 disc's try never to touch the shiny part and always either put it back in the case, or what I do is use the lids to my blank CD's to store them in.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 25, 2010 | Sony Playstation 3 (PS3) Console
Trouble with the login
u might have some corrupted files
i cant remember how to do this a little but turn ps3 off so it has a red light
then hold the power button u hear a beep
then after a few seconds when u hear another one get ure finger off
then follow the stuff it says and if there are options like restore defaukt settings or blah blah
click the one that says corrupted data might be number 3
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
Wont switch on
Maybee a dodgy power lead try replacing it
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
I cant hear the sound on the ps3 when the hdmi plug is how can i fix that
ok take out the hdmi cord and make sure its not dusty or anything then put it back in and when turning on your ps3 HOLD the on button for 5 secinds you will hear an extra 2 beeps and you will get a screen saying a hdmi device is connected blah blah blah just set it up to hdmi again and see if it worked
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 dvd drive gets stuck
Hi Kris,
Sounds like the mechanism is abit jammed inside (can be due to dust or lack of grease, or purely has become mis aligned.
Also, your laser seems to be wearing our, this can be serviced or replaced. - Fully guaranteed for 12 months.
James
Manager,
www.fixmyconsole.co.uk
May 04, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Controller USB not working?
Flip the controller over, and press the reset button. It's to the right of the middle-top screw ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
Grabbed this from Kaivarri. Thx!
Check out my new common problem and easy repair and tips guide here:
http://rescuetechla.blogspot.com/
If you've got any more questions please feel free to email me. Don't forget to rate!
Thanks!
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Freezes On The Wavy Lines
I had the same problem.
Whilst the machine is turned on, plug in the usb to the wireless controller and the PS3 should detect it and ask you to press the ps button (center of controller). Do this and you should get a menu, select RESTORE FACTORY SETTINGS, and you will have to input time, date etc but it does get machine working again - previous data is lost and you may need to keep trying as machine took several attempts to detect wireless controller - just persevere!!! I tried pressing buttons etc, switching off but nothing else worked for me ... Hope this helps
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
My ps3 won't restore
Ok so with mine I turn it on and it says something along the lines of the file system is corrupted. Restore now and it restores and restarts but it asks me to do it again and again etc. so mine is screwed I am going to have to send it in how you figure out if you need to send yours in is hold down the ps3 power button (MUST BE OFF FIRST) it will turn on just keep holding it until it turns off then do it again but this time while you’re holding it you’ll hear a beep and then 2 beeps after you hear the 2 beeps let go you’ll go into this thing called safe mode ok from here you’re going to press restore file system I think its option 3 it will say "preparing" ok now if it ends up taking more than an hour and it still says preparing unplug your ps3 and go back into safe mode and your
unfortunately going to have to press restore this will remove everything you have on the ps3(Saves, movies, music, etc.) now after you pick that option wait about 4 hours if it still says preparing then I hope you have the warranty cause you’re going to need a entirely new ps3 I have heard of there being a way to restore it with a cd but you will need to do some searching and talk to an expert in that stuff I wish you good luck
May 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
