Question about Norcent Technologies TV2001 20 in. LCD Television
My son's 20" LCD Model LTV-2001 will not turn on.
    Top Expert:
  • Norcent Tech... Master
  • 45,139 Answers
Could be an open internal fuse or power supply failure
Posted on Jun 01, 2017
5 Suggested Answers
  • 111 Answers
SOURCE: My tv wont turn on the red power off light is on
if you have audio then the backlight is not working
Posted on Oct 10, 2010
budmrtn
  • 11361 Answers
SOURCE: when I plug the power
Right now the standby 5vdc is working but it may have gone into safety shutdown due to failed power supply or shorted circuits in the backlight inverter board. You need to troubleshoot it to narrow down the causes first before buying the wrong parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 02, 2010
  • 11800 Answers
SOURCE: NORCENT MODEL PT4231.TURN THE MASTER
The continuous flashing indicates that the power source is in protected mode: another part inside the tv has failed, it draws an excessive amount of current and that has been detected by the safety system of the power source who has shut it down to protect it and the rest of the tv.
Since the status light goes to orange for a few moments before going red it means that the problem is outside the power source. The most probable cause is indeed with the mainboard; if it would have been one of the Sustain boards the failure would have been much more brutal and instantaneous (no orange on the status light) .
To certify that you will have to test the mainboard with an oscilloscope to find out if the processor is operational. If you don't have one just swap it.
Posted on Feb 12, 2011
anticlock
SOURCE: Norcent 42
Did you ever get this problem fixed? My tv just started doing this today. I have the same exact one...
Posted on Feb 22, 2011
LTV-32W1 kind of works Westinghouse 32" LCD
After reading this detailed description, it sounds that something wrong with either its power supply regulator board [loose solder terminals] or like something, or a loose connection to flat cables connected between LCD panel and T'Con board. Anyway, if you wish to get some service tips to this kind of intermittent problems to LCD TVs, check this link. You here states that, you've seen something on screen for a while, indicates that there is no problem to main board. Check the set well, with patience.
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 09, 2013 | Televison & Video
How can i find a power supply for LTV-20SD
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
May 03, 2010 | Astar LTV-20SD 20 in. EDTV-Ready LCD...
Astar LTV-32HGB blinking power indicator light
this sounds like typical power supply problems. these units have a stand-by power thats always active;even when unit is off. this allows the settings to be remembered by the u-con. (microprocessor) when you unplug the unit it will reset to factory default, thus erasing faulty power-supply data from improper voltages.(usually low readings) swollen capacitors on power-pcb will effect operation. recommend replacement of all electrolytic caps on power board. even smd's (surface-mounted-devices) can be leaky. they can be checked in circuit with an ESR meter. this is an analog sweep meter (needle gauge, not digital) that can detect faulty, leaky capacitors.
Mar 09, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
TV will not come on
Hello, Your tv main board is defective. just call me at 323-767-6030 and I will help you go through the trouble shooting.
Jan 11, 2009 | Astar LTV-20SD 20 in. EDTV-Ready LCD...
No power no picture no sound Astar LTV 20PW
Hello friend,
Your tv can be fix, I am the right person could help you fix your tv.
please call 323-767-6030.
Jan 03, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
ASTAR 20'' LCD TV
TO ALL WHOM IT MAY CONCERN REPLACE THE WHOLE SUPPLY WITH NEW ONES AS IN 2OR3 SEPARATE ONES FROM HALTED ELECTRONIC SURPLUS OR HSC IN SUNNYVALE CALIF 408 AREA CODE LOTS OF ROOM
Feb 16, 2008 | Astar LTV-3001 TV
Norcent Technologies TV2001 20 in. LCD Television Logo
37 people viewed this question
Top Norcent Technologies Televison & Video Experts
Jaime Hernandez
Mat Taylor
Level 1 Expert
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
