Related Tags:
This problem should be removed because:
Problem with Kenmore 64702 Top Freezer Refrigerator
drip pan overflow
A few days ago I noticed a puddle of water coming from beneath the refrigerator. I looked it over and noticed that the drip pan in the back was full to the rim. I sqaked it dry and thought I would take a look the next day. Sure enough the drip pan was full to the rim again. I repeated the drain process again and the pan filled again (x 3 days). What could possibly be the problem?
Solutions (1)
Best Solution
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
Water leaking under refrig
Ever few days we see a puddle of water coming out from refrigerator to the front, my husband check the water line connections one day when...
Foul odor from beneath the frige!
We have a Frigidaire Professional Series refrigerator (model:PLHS238ZCB1), which has had a foul sour smell coming from beneath the frige for...
Whirlpool model number ER2CHMXPL02.
Whirlpool model number ER2CHMXPL02. Freezer drains into refrigerator and water puddles in bottom of fridge. The pan underneath is dry.
water is leaking inside of the refrigerator on the
water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from...
Add Your Solution
Icemaker problem. Water gets outside the cube
Icemaker problem. Water gets outside the cube tray and down into the bottom of the freezer compartment.
water is running down to bottom & freezing,
water is running down to bottom & freezing, is it the hose? If so, where is it located? Not sure of model number but...
need to reverse the doors on a top freezer refer.
The handle is the problem. cannot seem to remove it. The refer is a kenmore model no. 25368842791. The doors now open...
broken vegetable drawer just need to buy another
broken vegetable drawer just need to buy another one
Ice maker not freezing ice and water puddle...
I had a diner party last night. I emptied my ice bin in my freezer. I put it back and made sure the bar was in the on...
Fix-O-Meter
127
127 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Kenmore Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
