Question about Samsung RS2630SH Side by Side Refrigerator
How to remove fan blade from condenser motor on samsung rs2530 refrigerator
5 Suggested Answers
Speed boy
  • 76 Answers
SOURCE: Samsung refrigrator fan replacement
The blade only have one screw,You would see a plastic looks like whasher on the back of the blade where the shaft is,it has 4 points sticking into the blade,use a flat screw driver to wedge it off.
Good luck...
Posted on Sep 10, 2008
adnanbhatti
  • 1188 Answers
SOURCE: my side by side samsung RS2530 bbpfreezer is not freezing any ice
Are you taking too much ice in too short time? The freezer needs some time to freeze the water to form cubes. Another reason is that the water supply line may be blocked by air bubbles. Ensure that the water supply is adequate.
Posted on Aug 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Samsung RS2530 Series
Click Here=> RS2530BBP User Manual and if you need Product Support Click Here=> Samsung Appliance Support and if you need Technical Support or out of warranty feel free to ask me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 22, 2010
hvac1960
  • 2133 Answers
SOURCE: The refrigerator part is 60 degrees and the
Please follow these steps.
Keep temp setting at 5 degree. Check defrost timer, thermostat and frost heater are working properly. Call repairman to check above all. Thanks.
Posted on Feb 02, 2011
Panel between the of doors rs2530bwp is very hot
f the space between the doors is warmer than normal, there is a problem with the airflow over the condensing coil. First, remove the front grille below the door. Then use a brush and vacuum to clean the condenser coil. After the coil is clean feel for warm air blowing from the condenser fan. If you do not feel any air, the condenser fans probably not running. To check the fan pull the refrigerator out from the wall and unplug it. Then remove the lower access panel. Once the panel is removed, try to turn the fan blade by hand. If it turns free, plug the refrigerator in and see if it is turning. If the motor is not running a voltage check is required to confirm the motor is defective. If you have a meter and feel comfortable making live voltage checks, check the ac voltage to the motor. The reading should be at least 110 volts. If you have the voltage, the fan motor has to be replaced.
Dec 26, 2014 | Samsung Refrigerators
My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
Aug 12, 2011 | Refrigerators
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
Noise from condenser fan. I cleaned the blade and the surronding area. Put some w-d 40 but the noise is still there. It is cold. Should I replace the motor? how hard is it to do? kenmore coldspot...
Go to www.searspartsdirect.com enter your model number and select model number search.
Here you can see a diagram of the unit. The fan motor cost 95 dollars.
It depends on the type of noise it is making.
These motors when failing tend to hum when trying to start which is a sign of a dry bearing.
Rattling sounds or ting ting ting sounds are either a lose fan blade (check the cheap retaining clip on the front of the shaft .. it may have wiggled forward causing the blade to wobble) or a lose mounting screw.
Also I can't tell from the diagram how close the fan is to the drip tray(tray evaporator) These fans not only aid in removing heat from the condenser.. they help evaporate the water in the drip tray.
If you remove the motor.. have it tested before replacing it. At a hundred bucks it's worth a trip to a good electric motor shop.They generally will test it for free.
If you are able to determine the voltage and hook it up out of the cabinet you may save yourself a trip.
Chances are it's a lose mounting screw or that front blade retaining clip.
Best of luck!
Apr 30, 2011 | Kenmore 64254 / 64252 / 64259 Top Freezer...
When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a noisy cooling fan. I have cleaned and removed all the dust from the vents in the compressor compartment, but the fan still make a squeeking sound. Can the fan be oiled or greased or should it...
Is the area between your fridge and freezer smoking hot? Can you smell the rubber seals melting? Does your fridge squeak like crazy? You have an issue with your condenser fan. You can save about $50 by fixing the fan motor yourself. I'm no engineer but this was an easy fix. 1) Unplug the fridge. 2) Take off the lower back panel covering the condenser and fan. 3) Unplug the fan (on the top left from the fan. 4) Slide the fan out of the bracket 5) Take the fan blade off. (This will take the most time and TLC, it is glued on) 6) Take the two screws out of the back of the housing. **The fan motor should be free of the housing and blade** 7) Remove the two screws from the fan motor housing. 8) Pull the shaft out of the motor and clean all parts with some oil and a rag. 9) Make sure all moving parts are well oiled then put the shaft back in the motor housing. 10) Replace the motor housing screws 11) Replace the motor into the fan housing and replace the screws. 12) Slide the fan blade back onto the shaft (I used some super glue to help hold it in place) 13) Slide the fan housing back into place 14) Plug the fan into the socket 15) Plug in the fridge to make sure your fix worked (it may take a minute to kick on) 16) Replace the lower cover
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
The fan is making too much noise
Hi. You didn't state which fan you are having issues with, so i will address both areas.
The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the next problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. If the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
NOTE_ If the fan blades are not warped, and rubbing against the shrouds, this will indicate that the motor that rotate the affected fan is damaged. It must be replaced, in this case.
Dec 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Sears side by side door jamb hot
dirty condenser coils or the condenser motor is not working, clean the coils with a vacuumm and brush and make sure the condenser fan motor behind the ref. is working. their is a access panel behind the ref. remove the access panel in rear and look for a motor, the blade should be spinning if the ref is running. be careful blade is sharpe dont touch blade if turning. motor runs around 29.99-89.99. and labor 75-125.00 depending on who u use and were u live . sometimes we find objects, pests caught in the blades. check all that before u call for servive . hope this helps.
Oct 07, 2009 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
541 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
