Question about Broderbund The Print Shop 21 Deluxe Full Version for PC
Cannot uninstall printshop 21....cannot find disk
    President:
  • 2,340 Answers
Then go to http://www.revouninstaller.com/revo_uninstaller_free_download.html and download Revo.
Choose Advanced when asked for removal type.
Posted on Nov 14, 2010
SOURCE:
I get an error code 1321 when trying to uninstall printshop 2.0 I can't run it either
Try downloading ccleaner. www.ccleaner.com I their "tools" section, you should run the uninstaller for that program. It is a FREE downlaod and I have used it for years...
Good Luck...
Dec 01, 2014 | Broderbund The Print Shop 20 Deluxe for PC
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I've installed Printshop 21 on my new computer. I
Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
Nov 14, 2017 | Broderbund Print Shop® 21 Pro Publisher...
How do I remove the printshop cd label creator from my computer? I choose remove, it goes through the motions, but does not remove it. susanaconde1@gmail,.com
Before you uninstall it,
Open task manager and in the process tab find the respective process of your cd lable creator and click end process.
Now you can uninstall it.
Apr 05, 2010 | The Learning Company Print Shop CD Label...
My HP Color Laserjet CP3505n gets an error message when trying to print page size color photos from Printshop 21. I can print from other programs without problems.
check with broderbund to see if they have a driver update and check with HP at
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?taskId=135&lang=en&cc=us&prodSeriesId=3290546&prodTypeId=18972
this is the driver site for your printer.
Feb 19, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I purchased printshop 2008, couldn't get it to work, returned it for another and the same thing happened. I get error code 2908. I bought it at staples and can't get my money back. I would appreciate it...
Printshop takes an awful amount of memory. You might get it to work if you uninstall then do a clean install by making sure all other proggys are turned off while you are installing. You also need to clean up your startup programs. To make sure there are not too many all starting up . How many little icons do you have in the lower right hand corner and what are they for?
Aug 10, 2008 | Computers & Internet
Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
172 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
