I have a Sony Bravia LCD TV (KDL-40Z4100). My problem is that they picture was darker on one side then the other, while the other side was normal color. Now the picture is completely blank. The tv will click on and off two times and then goes to standby mode that indicates a malfunction. I took the back off to try and take a look and the clicking noise is coming from the left side of the tv (looking at the back of it). Is there something I need to replace or is it fixable?
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
waynejamescm
  • 67 Answers
SOURCE: Have a new Sony Bravia
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
  • 1039 Answers
SOURCE: Sony Bravia TV automtaically goes on standby.
Probably the main board. This has a 1 year mfc parts and lobor warr. I would contact Sony for the nearest auth servicer. If you open it you will void the warranty.
Posted on Apr 26, 2009
Faces have distorted colors
It may be that you have a solarised picture that can be correctly restored by entering the service mode and performing a system reset. but you may have to take it to an engineer
Nov 18, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
My sony bravia 40z4100 picture weird people skin look red or green shiny.the menu looks fine.anything with letters looks fine,
Check and replace the T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 17, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Distorted Colors on Sony Bravia KDL-40Z4100
T'Con board fault. For most Sony sets; T'Con is an integral part of the panel. It will be best to contact the authorized service center for Sony in this case. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Faces looking strange on sony kdl-40z4100
T'Con board suspected. Contact the authorized service center for Sony.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 31, 2014 | Sony Bravia KDL-40Z4100 40 in. LCD TV
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
