Question about HP PSC 950 All-In-One InkJet Printer
Change laugauge on printer - HP PSC 950 All-In-One InkJet Printer
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Can nikon charge laugauge ?
Yes. Tap MENU to bring up the menu screen. Tap the wrench icon to bring up the setup menu. Language is the eleventh item on this menu.
Feb 19, 2013 | Nikon COOLPIX S200 Digital Camera
How to change from serial communication to parllel com mode
OS settings to change port ---------------------------------------Click Settings > Control Panel > Printers and Faxes > Select your installed printer and right click on it > select properties > Ports > change serial port to parallel (COMx to LPTx)
Printer Settings to change port-------------------------------------------------Click here for EPSON user manual and refer page number 36 for printer settings. Change I/F mode to parallel (Interface mode) as instructed by Epson.
Feb 17, 2012 | Epson LX-300 Matrix Printer
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Jul 09, 2011 | Zebra 105SL Thermal Label Printer
We recently changed high speed networks and our IP address changed. Since the change our zebra 2844 printers are not working. Is there a way to change the ip address for these printers? If so how.
Turn the printer off.
Disconnect the power-cord.
Reconnect the power-cord.
Turn the printer on.
It should automatically reconfigure itself, and get a "new" IP-address.
Then, you'll have to "delete" that "networked-printer" from your computer,
and then reinstall that "networked-printer", so that your computer can "talk"
to the printer at its "new" IP-address.
May 12, 2011 | Zebra Eltron TLP 2844 Thermal Label...
I've got some problems with my zebra zm400 printer. It says error ribbin out
May 05, 2011 | Zebra 203DPI Printer
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
We have 13 s4m Zebra printers. We try to change from thermal to direct. Which was no problem during our initial test. But when we try to change actual printer that was being place inside a cooler we kept...
Sep 16, 2010 | Zebra S4M Thermal Label Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
HP PSC 950 All-In-One InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
