Question about Microwave Ovens
How to check magic chef mco153sf fuse, where is the fuse
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: my magic chef micro does not work. I replaced the
In many brands, there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some questions to help you or someone you know troubleshoot it:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
Posted on Dec 07, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Posted on Dec 23, 2009
  • 6771 Answers
SOURCE: have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Posted on Feb 06, 2011
Testimonial: "thanks for your info."
  • 71 Answers
SOURCE: my magic chef microwave, model
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Posted on Oct 28, 2011
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
Magic chef microwave buttons will not work but microwave is on
its a connection problem probally from a bump while driving the camper - you can dismantle the microwave yourself from the back and reconnect the jared wiring, or just replace it with an industrial one that can handle the camper abuse.
Jan 04, 2014 | Magic Chef MCD990R Microwave Oven
Where is fuse located, magic chef mco153sf microwave oven
fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-0.jpg fuse-located-magic-chef-mco153sf-4e5eoo02uytabw1vwgixtmyx-2-2.jpg
Cylindrical fuse is located inside a cylindrical casing (approx. 2 inches long), found suspended amongst the wiring.
The fuse is NOT fixed to a circuit card nor another fixed point in the microwaves, as is common with other microwaves.
Apr 13, 2012 | Magic Chef Microwave Ovens
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
The microwave fuse keeps blowing up. Any idea why?
My Magic Chef microwave keeps blowing fuses (5 fuses) when close the door. Anybody has any idea? It is the first and last time time that I buy Magic Chef's products if their enginers don't come out with a solution because I just got it just over a year.
Thanks for your time and your expertise.
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
No power at all to magic chef microwave. Checked the outlets working
check the fuse.. the location should be specified in the manual.
Apr 14, 2011 | Magic Chef Microwave Ovens
Blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Mar 01, 2010 | Magic Chef MCD1611 Microwave Oven
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
Micro ios totally black . Had to reset the breaker ; is that a clue/
It has a fuse inside. Check the door switches while you're in there. The one in series with the fuse can weld in the "on" condition and blow the fuse and/or the circuit breaker.
Jul 23, 2008 | Magic Chef MCD990W Microwave Oven
Microwave Ovens Logo
186 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
