I have a lennox furnace that is about 25 years old and for the last few days it doesn't want to kick on. I replaced the thermostat thinking that was the problem, but it wasn't. The problem that I'm having is that when i turn the funace on it will click a couple of times and then turn off. I keep tuning the thermostat on and off until the furnace finally clicks on and gets the heater going. Im not sure if the electric start that lights the pilot light and then the furnace is going bad. Once i have the furnace going, it will warm up the house and after it reaches the set temp. it will turn off and not come on again. Any suggestion on what the problem could be?
    Genius:
  • 1,015 Answers
I would suggest that you have someone turn thermostat up to call for heat while you are watching. Being that old it may or may not have a induced draft motor on it. It it does the draft blower should come on first, then spark igniter,then pilot ,next the main burner,and after a short period the main blower. If you do not have induced draft motor the spark igniter should come on as soon as thermostat calls for heat. If it doesn't I would check all electrical connections making sure they are all clean and tight fitting. Just follow it through step by step . You can use volt meter to check across red and white wires from thermostat to where they hook into furnace. When you are calling for heat you should read about 24 volts. I would be inclined to replace spark igniter but if it does what it's is suppose to then I would go to gas valve. It might be worth your time to check connections on t-stat. I have occasionally seen wires that were broke under screw and some time make connection and other times not. You can also remove red and white wires from t-stat and temporairly touch them together. this should turn heater on. Hope this helps. Thanks.
Posted on Nov 14, 2010
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
G50 lennox furnace ignites and burners kick in but only burn for a few seconds and then shuts off . Appears there is heat sensing probe in front of burner. Ibelieve it is the heat sensing probe which...
the part your describing is a thermal coupler and you'll need to go to a heating and ac supply company. some small local hardware stores might have it but never found one at the big stores like home depot.
last resort if its cold where you are call the local gas company and get them to fix it. you'll have to pay for the repair call.
Jan 17, 2011 | Superior Lennox Blower Thermal Sensor -...
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Very loud induced draft furnace
when you tighted it it very well could have done damage to the motor or you could have it off kilter 1 of the 2
Feb 04, 2009 | Superior Lennox Blower Thermal Sensor -...
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Nov 06, 2008 | Heating & Cooling
Heating & Cooling Logo
272 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
