Question about Gateway M275 Tablet PC
Screen going nuts
My tablet top was already missing a screw, and my son turned the tablet top 360 degrees a few times. It must have twisted the wires or something, because now I can't do anything, the screen just zigzags. Any suggestions??
    Novelist:
    Scholar:
  • 70 Answers
The connector is damaged. The connector was meant to only rotate 180 degrees and only in one direction. You are partially correct. The wires are twisted. Probably beyond repair. You could open up the laptop and the screen and look at the wiring and the connectors and see if they have just been dislodged from the connectors. Typically they are sliding connectors with film type wiring. You pull out on the connector to release the film. Otherwise, you are in for a rude repair bill.
Posted on Jun 19, 2008
How do I reset an Orbo Jr. 4GB Android 4.1 five multi touch tablet?
After a lot of searching, I found some information for you;
You can attempt to do a "hard reset" on the tablet. Some models have this feature while others do not. In order to do a hard reset, hold down the volume up button along with the power button until the Orbo Jr turns on. Once it starts to power up, you should see a menu in the top-left corner of it with an option called "factory reset kernel." Use your volume down button to select it and the screen brightness should restore. Hope this helps you get it back up and running!
and this
The easiest way to unlock the Orbo Jr if you have already downloaded things from the Google Play store is to input the wrong pattern 5 times in a row. If the system is fully updated, you should see "forgot password" on the screen. Hit that and put in your google email and password and it will unlock the tablet allowing you to put in a new pattern. Hope this helps ya out!
Orbo Jr Tablet Review
Sep 21, 2015 | Tablets & eReaders
Nexus 7 tablet not charging
Had the same issue just two months after buying mine last year. It must be a very common fault with these tablets. I think you may just be covered for one year, but go back to where you bought it and they can either send it away to be repaired or fix it instore. It is something to do with the charging connector inside the tablet being loose. Since it is not a big 'repair' to fix, they surely should do it free of charge.
My son-in-law, who knows these kinds of things, says that it can be repaired easily be anyone who can open the tablet corrrectly.
Sep 03, 2014 | Google Nexus 7
My HKC A072D will not go past the initial HKC start up screen, at all, nothing has helped so far
This happened to my nieces HKC 7" Tablet and I held the Power button and the Home Button down for about 10 to 15 seconds and it reset everything and is still working to this day
May 08, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Tablet screen is white
Check with the manufacturer or wherever you bought it. Sometimes they will fix it free, but you have to go through a few hoops, like filling out some paperwork and sending the unit back to the company. The downside, is that if they think it is damaged, instead of a defect, they could charge you. But if there is a warranty, then I would think the could fix for free. It all depends on the manufacturer. I has an ASUS table that the screen got cracked. After doing some research on the tablet, I found that some of the tablet had a defect on the way the screen was manufactured that would make it crack easier or for no reason. So do a little homework and see if there are any customer complaints about the product.
Feb 08, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Display colors are screwed up
my son deleted everything I don't have a back-up the launcher has stop working I can't download or restore help me please
Feb 02, 2014 | Proscan 7-Inch Android Internet Tablet,...
How to rotate asus tablet webcam display 90 degrees?
turn on the auto rotate screen and if that doesnt go in the top right hand corner there should be a button there, click on it and it says rotate just keep tapping it until it rotates to your desiered position.
Nov 30, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
Klu LT1041 tablet by Curtis screen went black and now will not turn back on
My son put a 9 point lock on his tablet and does not know the unlock pattern. I have done the reset button so many times and need to get back to the factory settings. Can some one help me figure this out? It has been locked for 4 weeks and im loosing my mind trying to unlock it.
Apr 05, 2013 | Tablets & eReaders
I have two hp tc4200's that I bought for my son's. One of them the touchscreen will not rotate when in tablet mode and the screen turned black and I cannot get it to come back. You can hear the sounds and...
The problem could be a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Feb 06, 2010 | Compaq tc4200 Tablet PC
Dissplay not working
I had the same problem on one that I bought, that was used. You have to take out all of the little grey plugs and remove the screws underneath them. My cables were all fine. I had a connection inside the monitor area, near the top. There is a ribbon cable with a flat, wide plug on it. I had to uncompress the sides of the plug & jack. It cured the problem. About 4 months after I had it working, I found out the previous owner used to pick it up by the screen.
Jun 14, 2008 | Averatec C3500 Tablet PC
Gateway M275 Tablet PC Logo
Top Gateway Tablets & eReaders Experts
Daniel Florin
Daniel Florin
rongg
Ricky Ostrom
Ricky Ostrom
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
