Question about Bosch Axxis WTL 6307 Electric Dryer
My Bosch Exxcel Condenser dryer is not drying properly. The cycle stops and the container light keeps flashing.
4 Suggested Answers
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
SOURCE: Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Posted on Apr 01, 2010
SOURCE: Bosch classixx tumble dryer container full light
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
Bosch exxcel maxx freedom washer dryer filter will not open
You will need to keep working it. It will open.
Nov 02, 2012 | Washing Machines
I've got a 2 yr old Bosch Exxcel dryer but its in my garage and we've recently had unprecidented cold weather with night temps of -12C The dryer seems to work fine but it keeps stopping after one cycle...
Sorry to read about your problem, I hope this helps you out.
yes and it has to be around 35 to 40 to defrost...may take 3 days at that temp
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Bosch Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
Nov 16, 2009 | Bosch Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
WTV74307GB
the warning does not strictly mean filter only
there is a lint blockage somewhere in the vent system and there is only a single response the dryer knows to make
fan
fan housing
duct
outside vent
could all be sufficiently blocked to set off the warning
Oct 19, 2008 | Dryers
Filter light flashing on bosch exxcel condenser, repeatedly.
This should help you find a manual.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Dryers
WTV74307GB
take the lint screen out and clean it with a toothbrush and warm soapy water. You may be using too much softner. If that doesnt work, the control board may be bad.
Mar 30, 2008 | LG DLE2514 Electric Dryer
Bosch Axxis WTL 6307 Electric Dryer Logo
187 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
