Question about Sony RDR-GX7 DVD Recorder
I can not get the recorder to read original dvd from the store only copies
  • Sony Master
  • 19,396 Answers
Hi.
A firmware update will probably be able to solve the problem.
Here an update for the USA model, instructions on page.
Update also here.
I quote procedure listed in first link above.Also ensure that you are installing correct update version for your zone. See the part realative to testing procedure in the first link. Ensure you follow thoroughly instructions or your unit may result damaged.
"Copy the attached RAR file RDRupdate.zip to your computer and Unzip.
Copy all of the unzipped data files to a CD-R disc.
ChkFlg.txt
FNT_DATA.BIN
ROM_DATA.CM1
ROM_DATA.CM2
Ver.bin
[VERSION UP INFORMATION]
From RDR-GX7 : Ver1.10 to Ver1.30
[VERSION UP PROCEDURE AT THE SERVICE]
1. If the unit is in the locked condition of Disc can not eject, press the lever on the right side of DRIVE UNIT, the tray opens and remove the disc. (Refer to the RDR-GX7 S/M, page 5)
2. Reset by removing and reinserting the AC plug.
3. Playback a DVD (any working DVD disc) to initialize the systems data for repair, then remove the disc from the unit.
4. Place the version up CD on the disc tray, then press PLAY button.
5. After loading the disc, select YES of version up which is displayed on the monitor,
then press ENTER button.
6. The version upgrade starts automatically.
7. After upgrade is finished, the tray opens automatically.
8. Remove the upgrade disc from the tray.
9. With the TRAY open, reset by removing and inserting the AC plug.
When update is complete. Unplug the unit from the AC Mains then re-plug. This resets the unit."
Regards
Posted on Nov 14, 2010
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
My dvd player won't read copied dvd movies but willl read store bought dvd movies in the device manage is says "unable to recover TOC error 0x13570001
one answer is to format the movies after you record them on dvd player. They would then be more likely to be read by the pioneer dvr.
Mar 01, 2010 | Pioneer DVR-107D DVD±RW Burner
Problems with the DVD-VR375
If discs skip, freeze or doesn't read, along with the recording problem, then it could be a dirty lens. If cleaning lens doesn't fix it the optical p/u assembly will have to be replaced. Make sure the items you are trying to record aren't copy guarded.
Sep 01, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Aug 28, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Jan 04, 2009 | Zenith XBR716
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
VR2945 DVD recorder VCR combo
Use it as a boat anchor!!!
I've tried and tried and gave up.
Jan 17, 2008 | GoVideo Go Video DVD/VCR Combo
Why won't my computer read it?
Finalize the disk in the computer.
Jul 31, 2007 | Toshiba D-R5 DVD Recorder
Sony RDR-GX7 DVD Recorder Logo
176 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
