Question about Nikon COOLPIX S230 Digital Camera
When I take pictures inside, they always turn out yellowish. I have the mode on scene. Why are they turning out yellow?
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: yellow gym pictures
The lighting in the gym was the cause most likely. Try setting the white balance to a different mode
Posted on Feb 07, 2008
SOURCE: Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Posted on Jun 10, 2008
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
Yellow cast to indoor pictures, when I take pictures at my kids baskteball games and other indoor events, concerts, etc, the picture has a yellow tone to it, like the light is not sufficient, but it is...
This is most likely the White Balance, if the pictures look yellow under artificial light.
I cannot find a manual online so I do not know if you can set the white balance yourself.
If you can, set it to artificial light. Remember to set it back for normal shooting.
You might like to try the Indoor Scene Mode, this should set it for you.
Hope this helps.
Feb 16, 2010 | Olympus FE-310 Digital Camera
When the set is turned on, the screen displays a lot of blue dots like an outer space scene except the stars are blue and there is a large circular area in the middle that is yellowish. I still get a...
Hello: Unfortuntely the Optics engine will need to be replaced the blue lcd chip is failing, this will get worse as time goes on. Replacing the optics engine is the only solution to repairing this set back to spec's. Most call them Light Engines..This site will give you cost and example of what one looks like.
Http://www.tristatemodules.com
Nov 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
When I am in action mode (with the dial turned to the running man my picture is blurry and yellow
The mode you mention above is prioritized for speed moving object such as racing, basketball game, etc...
the blurry condition is caused by the movement was too fast so the camera couldn`t capture it, the yellowish picture is caused by unmatched white balance presetting
according to my experience, when you want to capture a moment like this,
switch the dial to S (shutter) mode, set the shutter speed to 1/80 or faster, using a flash will be an advantage, don`t forget to set the white balance to auto option
hope this advice help you with your problem
Nov 02, 2009 | Nikon D60 Digital Camera
Pictures are blurry - have the red hand flashing
select flash in auto... normally when you turn off the flash. the hand appear...
Aug 06, 2009 | Nikon Coolpix L11 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Yellow gym pictures
Feb 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Nikon COOLPIX S230 Digital Camera Logo
168 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
