Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
It keeps getting stuck on the apple with the gears spinning.. How can I stop this?
  • Apple Expert
  • 481 Answers
WHen you hear the startup chime, hold the shift key down. Do not release the shift key until you see the login screen. Then login and examine your System Preferences for something you recently added that is incompatible with your system. If you can't find anything obvious, use the Console utility to examine the system logs and see what error messages occurred during your earlier unsuccessful boot attempts.
Posted on Dec 02, 2010
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
Bike will not move under its own power
Sounds like your clutch is getting stuck in the disengagement. Follow the clutch cable down and check to see if its moving or stuck.
Feb 12, 2014 | Harley Davidson Motorcycles
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
The computer frooze the other day and the command for force quit did not work so I unplugged it, after plugging back in, it will not go any further than the start page where the apple appears on white...
If your computer gets stuck on an Apple logo with a spinning gear, there are several steps you can take. Your best bet is to follow the steps in the following article:
http://support.apple.com/kb/TS2570?viewlocale=en_US
Note that this will likely require the startup discs that came with your computer. If you do not have them, contact Apple at 1-800-MY-APPLE to order replacements.
Jul 04, 2010 | Apple iMac G5 MA064LL/A Desktop
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Stuck on initial screen on power up
sounds like your hard drive died, you should take it into a repair shop unless you know someone that can replace the drive and re-install OS X for you. you computer uses a 2.5" laptop hard drive.
Jan 29, 2009 | Apple Mac mini G4 Desktop
XBox control
It's broken. Just buy another one.
Jul 27, 2008 | Microsoft MS Xbox 360 Common Controller...
Apple
Which screen is it stuck at? The spinning "gear"? The Blue progress bar scree? or the login screen? Answer this and i have your answer.
May 13, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
