Cannot open tray on DVD player. I put in the code that the book called for to unlock they tray but still nothing. I also took cover off the see if any connections were unplugged but all looked good. Power is coming on but when you push the open door button it says loading and then says no. Have any suggestions or should I just toss it? Thanks K
-   yes, I'm having the same problem with Toshiba SD-4000. I put in a CD (store-bought). It would not load. "Bad" showed on the front of the DVD player (it's a good disc). I pushed "stop" on the remote, and it showed "disc not ready" on the TV monitor.I pressed "open" on the remote, but the tray only opened about 1/2 inch. So I pressed "close", and unplugged the player overnight. Today, tried it again. I followed the directions in the manual for "tray lock and unlock", which is to press the "setup" button, and then punch in the #'s 2005 on the remote. But on the TV screen it said "can't open menu". I would appreciate any suggestions on how to open the tray and get my disc back. Thank you!
-   becky150
The DVD plays normally for 15-20 minutes and then it just stops as if the Stop button had been...
(More)
The DVD plays normally for 15-20 minutes and then it just stops as if the Stop button had been pushed. Occasionally, the screen breaks up as if the pixels are getting turned off and on.
I had a DVD player Toshiba SD 4000. The video output doesnt work, and Im watching the movies by...
(More)
I had a DVD player Toshiba SD 4000. The video output doesnt work, and Im watching the movies by another output, Yx is the name of the output. I went to see an electronic and he told me that was probably that my DVD lost it program, and that I need a number to fix it, but I dont have it. Now Im watching movies real bad, the image is distorsioned in some movies, sometimes when I put VCDs it works well, but not when I put DVDs. I change to free zone already (0) but still I have the same problem. If you could give me the code, or a place where to find it I will aprecciate, or if my DVD had another problem. Thakns for all.
