Laptop fault power supply will not charge battery or run laptop
  • minimatics Jun 22, 2008
    tried another power supply still dead. Stripped to check power supply jack connections everything looked ok
  • morgandy Nov 08, 2008
    I'm on my second battery from Dell for my D430 PC notebook.
    The first would not hold a charge, so I got shipped another. It's been a month and now I have the same problem.
    I've used two different adapters to make sure it wasn't that.
    Is there a setting or two I can check?
    Thanks,
    Morgan Mandel
Dell has a recall on these type of batterys. All OEM batterys made in japan, korea, and china. look it up for yourself. I already bought two batterys, both from Japan. both no good
Posted on Feb 14, 2009
    Genius:
  • 2,028 Answers
Start by replacing the power supply. That should cure it, if not, let me know, there is some other (more expensive) possibilities.
Posted on Jun 18, 2008
My dell studio 1737 will not charge the battery; however it will run on either the battery or the power supply at leas until the battery dies completely. The power supply is working properly. I have tested...
If the power supply is powering the system without the battery installed, and the battery powers the system without the power supply attached, but the power supply will not charge the battery in the system...chances are very high the charging circuit on the systemboard is not functional. There are a few possibilities as to why but the only real solution would be to replace the systemboard since the charging circuit is integrated. You could run through the charging circuit to locate the exact fault but you will need schematics in order to resolve if you are comfortable with micro-soldering.
To verify, if you can, place the AC adapter and battery into another 1737 and see if you get charging on the battery.
May 22, 2010 | Dell Studio 1737 Laptop
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Acer aspire 4920 charging mechanism failed
Most laptops, as in 99%, have one board and everything is on it. They don't really have a power supply since the AC adpater provides DC voltage already. There is just a voltage divider that take the incomming voltage and changes it to the various voltages the machine needs. The charging mechanism is also on the mainboard. I've very seldom seen a seperate power or charging board in a laptop. Unfortunately since you've already replaced the battery and the ac adapter and since the adapter is powering the laptop then there is definitely a problem with the charging circuitry on the mainboard. This isn't something one can repair unless you start changing micro components and ICs on the board which isn't recommended. Looks like a new mainboard or a new laptop is in your future if you want it to run off battery.
Another option is to get an external battery that mimics your ac adapter but that wouldn't give you a very long run time compared to the internal battery.
Don't forget to rate my solution in your premium thread as FixYa if you think I helped solve your problem. Thanks.
Aug 28, 2008 | Computers & Internet
Battery will not charge
Hi cdravi
Laptops have a power supply control section attached to, or part of the main board. This allows the laptop to switch charging on and off, and control power supply function to different areas of the machine. Sounds like you have a fault in this part of the computer. Off to Dell Service for that one I am afraid.
robotek
May 05, 2008 | Dell Latitude C610 Notebook
Not charging
Make sure you are using a 4.62A Power Supply (90watt) some of the knock-offs are only 65w (3.34 A). And you will never have enough current to charge the battery.
It will only run the laptop, but not charge.
The mobo sounds like it is good, if you had a power issue, you would have orange lights or blinking, and it would not come on at all with any power supply.
Mar 31, 2008 | Dell Inspiron E1505 Notebook
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
