Question about Panasonic SV-MP020 MP3 Player
Panasonic SV-MP020 Wait Problem
I tried resetting it but it still says wait and my computer still won't pick it up.
  • 3 Answers
Make sure the usb jack is all the way in the player. Mine had a couple of mm of metal showing and felt like it was in, the display lit up, said 'wait' and then 'goodbye' :-(. Only later did I realise the jack still could be pushed fully in a bit further, and then *bingo*, a working mp3 player
Posted on Jul 21, 2008
After downloading more songs onto the sv-mp020, i switched it on and all i get is wait...its been like ...
There is probably a reset switch somewhere that you will have to find, It will be tiny, Just big enough to put a needle in there. Press that and it should reset without losing any data. If it does the same "wait" thing again then remove any new songs you put on and put them back on one by one to see which one is corrupting the software and causeung the problem. Its a good idea to leave 25% free space on any storage device and especially MP3 players etc.
Mar 24, 2011 | Panasonic SV-MP020 MP3 Player
Freezes on wait
1. slide the [HOLD>] to ON
2. turn the unit ON (press the play button)
3.while the "HOLD" screen is displayed press the the keys in following order:
[MODE] , [ - ] , [ + ] , [ - ] , [ + ] , [MODE]
Note:
  1. You should press this keys as fast as you can without delay.
  2. All settings return to the factory preset. All recorded tracks are erased.
  3. Do not remove the battery during resetting. Doing so may cause the unit to malfunction.
Aug 19, 2008 | Panasonic SV-MP020 MP3 Player
Someone good with panasonic sv-mp020 please help me!!!what does OVER LIMIT mean?
Try resetting the mp3 player. You can do this by sliding the hold button over and then turning it on. While on it should say hold. Then you push mode (-)(+)(-)(+)Mode(+)Mode(+)
Granted, that will deleted all the songs you have on there so make sure you have them backed up somewhere you can place them back on there.
I hope this helps.
Jun 10, 2008 | Panasonic SV-MP020 MP3 Player
Panasonic sv-mp020w mp3 player
Make sure the usb jack is all the way in the player. Mine had a couple of mm of metal showing and felt like it was in, the display lit up, said 'wait' and then 'goodbye' :-(. Only later did I realise the jack still had to be pushed fully in, and then *bingo*, a working mp3 player
Apr 09, 2008 | Panasonic SV-MP020 MP3 Player
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Computer won´t recognize my player
format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
reboot your computer. put the battery back in the player.
plug it into the usb port on the computer. worked for me
Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
My panasonic SV-MP020 mp3 player does not turn on. and when i plug it into the USB, it's stuck on hello. help me pleaz!
Try reseting the unit.
1) Slide the hold switch to on
2) Turn power on.
3) While unit screen says hold, push: (mode)(-)(+)(-)(+)(mode)(+)(mode)
This should reset it.
Source: http://www.fixya.com/support/t129568-frozen_displays_wait
Aug 28, 2007 | Panasonic SV-MP020 MP3 Player
Firmware issue
go to www.panasonic.com. look for the tab near the top that says downloads or support. enter your model number in the search box. download the firmware. follow the instructions that come with it.
Apr 10, 2007 | Panasonic SV-MP020 MP3 Player
Frozen and displays "wait..."
unit needs to be reset this is a bit of a pain....... slide the hold switch to on..turn power on. while unit screen says hold, push (mode)(-)(+)(-)(+)(mode)(+)(mode) this should reset it
Jan 06, 2007 | Panasonic SV-MP020 MP3 Player
Panasonic SV-MP020 MP3 Player Logo
175 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
