Question about Intel D845GVSR Motherboard
How can i repair my mortherboardownself he cant give any beep or sound
  • Intel Master
  • 5,660 Answers
Suggest you start by unplugging the computer from power. Observe Anti-Static Precautions.
Use a can of compressed air for computers, and clean out the inside of the computer, as well as the inside of the Power Supply.
(Just do the best you can with the Power Supply. It won't be spotless inside the power Supply case when you are done.
The plastic 'straw' will be attached to the can of air's nozzle. The tip of the straw is inserted into the ventilation holes of the Power Supply, and a blast of air is applied.
Go to another ventilation hole, repeat. AGAIN, the computer is UNPLUGGED from power.
Hold onto the straw with one hand, and the can of air with the other hand.
Otherwise the straw could shoot off, and wind up inside the Power Supply's case. No FUN getting it out)
Next remove all Ram Memory modules, ('Sticks'), and clean the gold plated contact pins on the bottom with a pencil eraser.
Clean the contact pins on both sides.
If you are Not using a solid eraser, and the eraser on the end of a pencil, refrain from letting the metal band touch the contact pins.
Now use air to remove the eraser dust.
(If no air is left in the can of compressed air, air pressure from your mouth is sufficient)
Reinstall the Ram Memory modules.
Post in a Comment as to your findings when you are done.
Posted on Nov 18, 2010
My laptop gives an errrr sound when i want to start it up..pliease help
Are the sounds that you hear beep sound? Or any other different type of sound? If it's beep sound, then there is something wrong. Those are refference to let you know what to look for.
If it's any other sound, then you should verify your hardware.
Oct 07, 2015 | Computers & Internet
Beep noise
Hi, Anonymous I just loaned my brand new pair of listening ears to your local dealers chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD Bajaj Pulsar 180
May 06, 2014 | 2011 Bajaj Pulsar 180
Onida ac
PCB malfunctioning Repair it.
Apr 30, 2014 | Heating & Cooling
Epson t10
hello , change its catriedge most printrs give out beeps when ink is no more pls try this it will start to print.
Jun 25, 2013 | Office Equipment & Supplies
I cant start my laptop . when i press start i gives beep sound twice and blanck screen
Sub out the ram one at a time and power up each time, if you are lucky! the machine will start up, if not! remove the main battery and try again. If no change! the motherboard is the problem and you will need somebody to take it to the next level and find out the cause.
Apr 12, 2012 | Lenovo ThinkPad SL400 Laptop Computer...
My Olympus tough 6010 wont bring the screen on and its making a beeping sound i cant get it to work battery is charged
Hello
Thank you for using FixYa for your problem
Always check the batteries first, try another freah set but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
Toshiba Satellite m55 that will not pass post, 3-4-3 beep code
Sound like your Video Card has gone down i think it cant find the VGA bios
Nov 30, 2009 | Computers & Internet
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Intel D845GVSR Motherboard Logo
265 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
