Question about Lexmark X2500 All-In-One InkJet Printer
I have LEXMARK black # 28 and color # 29 but they are return cartridges I do NOT want to get cartridges from LEXMARK through the mail.What other STORE brands are compatable to LEXMARK X2500.If not allowed to use store brands compatable to X2500 I will destroy it and buy an all in one printer( NOT LEXMARK) and NEVER have to deal with LEXMARK again. Everyone I know has this same PROBLEM with LEXMARK.They do NOT fill refills and printer stops printing ink after certain time.You lose your ink balance and get screwed on new refill because they do NOT FILL them all the way.PLUS they charge way too much compaired to other printers. Thank you for any help.Helen
    Genius:
  • 1,181 Answers
Www PrinterFillingStation com Printer ink and Refill kits for your Printer
Try refilling them yourself, just do not let them run out and you have to push the reset button once to restart after it says they are empty
Posted on Apr 04, 2017
rizla
  • 1463 Answers
SOURCE: lexmark x2500 all in one ink refill problem
this might help you .
x2500
riz.
Posted on May 13, 2008
JackHeath
  • 1049 Answers
SOURCE: lexmark 5070 printer
Hard to tell...There are other issues which could contribute related to the printer itself, etc.
But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
Posted on Jul 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: need to know if its
Yes, there are kits available on the market that help you do that. But honestly, i wouldn't recommend doing that, as they only tend to screw up the printer in the long run. Moreover, printers these days have sensors that detect refilled or 3rd party cartridges, and will not work properly. This is being done by the printer manufacturers to prevent people from using cartridges other than their own....
Posted on Nov 08, 2008
SOURCE: Finding correct Cartridge ?????
#14 black #15 color it has to be lexmark ink only...it will not accept any others.....if you have a walmart where you stay at they should have a little machine by the ink cartridges....use that...that is where i got this info from and my printer is printing just fine
Posted on Nov 19, 2008
wayneard
  • 1901 Answers
SOURCE: Need replacement cartridge for my X2500
You can order them from Lexmark. (A bit expensive.) Links below.
#2 Cartridge
#3 Cartridge
Also available at Circuit City:
#2 & #3 Combo
Posted on Nov 22, 2008
Have a lexmark x5495 and have new cartridges. when printer is turned on, message states left cartridge incorrect.
Make sure that you are inserting genuine Lexmark cartridges and the correct versions for your model. The Lexmark X5495 takes 28/34 black or 29/35 color cartridges.
Try to re-insert your left cartridge and make sure it is properly seated in the carrier.
You can also try to reinsert your old left cartridge to determine if it's a faulty cartridge issue.
Oct 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
What numbers for cartridges for lexmark 2500
hello
go to the link below , it will give you the user guide : in it you will be able to get the part numbers for the various cartridges.
http://www.lexmark.com/publications/pdfs/2007/2500/v3709407_en.pdf
Item Part number Average cartridge standard page yield is up to1
Black cartridge p/n 28A
High yield black cartridge p/n 34
Color cartridge p/n 29A
High yield color cartridge p/n 35
Photo cartridge p/n 31
please rate my service
Nov 30, 2010 | Office Equipment & Supplies
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Replacement cartridges
    • Black cartridge 28A or 28
    • High yield black cartridge 34
    • Color cartridge 29A or 29
    • High yield color cartridge 35
    See user manual link below - Page 40The support site is here http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
    Direct link to the manual http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
    • If this solutions solves you problem, please do not forget to rate my solution.
    • If not, then please comment back so I can help some more
    Mar 31, 2010 | Lexmark X2550 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark printer
    Here it is:
    Black: 28, 28A, 34 High Yield
    Color: 29, 29A, 35 High Yield
    Thank you......
    Jan 28, 2009 | Lexmark All-in-One Printer with PictBridge
    What kind of cartdrige,black and color for my printer Lexmark X5495. Thanks
    You need a Lexmark 28 Black and 29 Color. You can get these easily at any Staples store or just try this link:   http://www.staples.com/office/supplies/c29_Inkjet-Laser-Printer-Cartridge-Ink-Toner-Finder-Lexmark-X5495_57173_Lexmark_Brands_27176_Business_Supplies_12328_a400_10051_true
    Sep 18, 2008 | Lexmark Office Equipment & Supplies
    Using refill cartridges
    That is because they cannot e refilled. The ones you get with your printer ( 28 & 29) are what Lexmark calls "return program cartridges", which means they are for one use only.
    I suggest you buy other cartridges that can be refilled. Those are either 28A or 34 (black cartridge) and 29A or 35 (color cartridge).
    Here is a link to Lexmark's site, where you can see the list of cartridges that are compatible with your printer.
    http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+Z845
    Hope that helps!
    Jun 05, 2008 | Lexmark Z845 InkJet Printer
    Lexmark X2500 All-In-One InkJet Printer Logo
    117 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
